Customs rear fenders
Discussion in 'The Hokey Ass Message Board' started by 4ford, Apr 22, 2019.
  1. 4ford
    4ford
    from Eagan. Mn
    Hello all.
    i have a 1941 ford coupe and thinking of welding the rear fenders on. what luck has anyone had with this and how did you go about this task? i know just weld the fenders on but what would you fill the gap up with that would hold and not crack over time, unless you just keep adding weld to the joint. just asking for some ideas and or pros and cons of this? I dont like the fender welting and or the gap between the body and the fender.
    thank you
    mike
  2. The37Kid
    The37Kid
    You have to weld the fronts to match. It will effect the resale value down the road. Bob
  3. 19Fordy
    19Fordy
    Unless you're building a custom, don't do it.
    You will be sorry if you ever have to replace the fender.
    Also, too easy to warp the body sheet metal.
    Hnstray likes this.
  4. rd martin
    rd martin
    from indiana
    I agree totally with all of the above.
    jvo likes this.
  5. Hnstray
    Hnstray
    from Quincy, IL
    One option is to work on both the body fender mounting surfaces and the fender flanges to get a really nice fit with consistent and minimal gaps. Lead would be the filler of choice for that too, but plastic filler would work if the ‘build up’ is minimal.
    A nice tight gap with no welt is, to my eyes, a good look while retaining the practical repairability of bolt on fenders.
  6. Sporty45
    Sporty45
  7. 4ford
    4ford
    from Eagan. Mn
    thank all you guys I think I will keep the fenders bolted on
    charleyw likes this.
  8. 41rodderz
    41rodderz
    from Oregon
    Less headaches .:)
  9. atch
    atch
    I saw well done molded fenders once that were bolted on then the seam was filled with seam sealer (think pickup bed). It looked like leaded but the fenders could still be replaced by digging out the seam sealer.
  10. Stogy
    Stogy
