Projects Rear end identification please
Discussion in 'The Hokey Ass Message Board' started by StarDiero75, Sep 19, 2017.
  1. StarDiero75
    StarDiero75
    Howdy everyone!
    So my rear end is needing some love and I thought it was a ford 8 in but it may be a 7.5. Can anyone please tell me what it is so I can start rebuilding it?
    It's got an octagon shape and 8 bolts.
    20170919_133357.jpg Thanks everyone!
  2. StarDiero75
    StarDiero75
    It's out of a 64 or 65 Falcon with a 6.
  3. 64 DODGE 440
    64 DODGE 440
    from so cal
  4. StarDiero75
    StarDiero75
    So it's not an 8"? I'm not a rear end guy, but the 8" pulls out from the front right? Then what's this?
  5. onetrickpony
    onetrickpony
    from Texas
  6. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    If you're at a point where you can upgrade to an 8 or 9", I would do it now. Ring and pinion sets are scarce as hen's teeth and they aren't they strongest diff to start with. You can find bearings and seals, but if there's an issue with anything else you're SOL.
    My kid managed to strip the teeth on the ring gear and I wound up going with an 8".
  7. StarDiero75
    StarDiero75
    Would a 8" be a direct fit? I'm looking at one on Craigslist. It's complete with the drums as well too. Would anything need to be done to the driveline to make it work?
  8. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    The tape measure is your friend. Measure wheel mounting surface to wheel mounting surface and look for something the same. I would think early V8 falcon would be close to bolt in. Driveshaft will be different, maybe brake hose.
  9. onetrickpony
    onetrickpony
    from Texas
    Wheel bolt pattern can be different on 8" depending on what it came in.
  10. StarDiero75
    StarDiero75
    A 8" out of a 66 mustang is about 2 1/2" narrower than the 7.25 I got now, what will that do to the car?
  11. Lost in the Fifties
    Lost in the Fifties
    If that differential is original to the Mustang, it should be a bolt-in.
  12. It is the rare 8 bolt henway.
