Technical Rear end for ‘51 chevy coupe
Discussion in 'The Hokey Ass Message Board' started by J_J2, Mar 9, 2020.
  1. 1934coupe
    1934coupe
    While you are looking at rears consider the bolt pattern you are running on your front wheels. 51 Chevy has 4-3/4" bc. Olds/Pont. is 5". Ford is 4-1/2". I'm too old to be dealing with two different bc's so I would opt for a 55-57 Chev. Or the Camaro/Nova rear.
    Pat
  2. J_J2
    J_J2
    I’m not quite sure I was going to go and take a look at it this weekend or I was supposed to anyway but I’ll try to find out more
  3. Nova Thug
    Nova Thug
    from SG Vizzle
    8.5” 10 bolt or 9” Ford will be plenty capable and parts galore..
    Chevy Nova 68-79 10 bolts are 60.25” wide but came with three different 10 bolts..
    68-72 had 8.2” 10 bolt
    73-79 had 8.5” 10 bolt
    76-79 had 7.5” 10 bolt - AVOID 7.5
    BOP 10 bolt for the other X body platforms have some differences Apollo, Omega, Ventura you might want to make sure you want verify.
    https://www.novaresource.org/axle.htm
    J_J2 likes this.
  4. J_J2
    J_J2
  5. and with the gear tag too! Looks like it may not be a molested unit, you did good.
    J_J2 likes this.
  6. southcross2631
    southcross2631
    If you need it narrowed or axles redrilled most competent 4x4 shops are equipped to do that .
    I use hudlow axle in Chattanooga,Tn. Shipping might be too much for you so look locally if you need anything.
    Speedway sells a reasonable disc brake kit with a parking brake.
    J_J2 likes this.
  7. J_J2
    J_J2
    It is completely unmolested, the gentleman I bought it from pulled it out of his truck was going to use it in another vehicle he had but ended up not doing the project. It seems like I got a pretty good deal.
  8. J_J2
    J_J2
    I found a guy here in town who apparently has done quite a few of these and everybody seems to rave about him, so I guess I’m going to give him a try as well.
