Ready to prime / paint questions
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Nov 18, 2012.
  1. harleycontracter
    harleycontracter
    First set of body panels are in. Looking to start the assemly of some of the parts I have . Body and frame have very light surface rust. And I want to end up with a flat primer type paint as a final. I have use epoxy primer but ends up kind of glossy. I don't want that. Probably a red oxide color. Any idea as to what steps I need to do in order to start painting.Also is there a paint that will let me end up with the look that will last ?
  2. jmpowie
    jmpowie
    you will need to spray epoxy first then your red primer color. If you just use primer it will rust in a few years. Primers let water get to the metal.
  3. matthew mcglothin
    matthew mcglothin
    ^^^what he said . You will defiantly need to seal the metal with epoxy primer. Then coat with some red oxide for your look you want. Just did my buddy's 39 ford this way.
    ImageUploadedByTJJ1353254321.581421.jpg ImageUploadedByTJJ1353254339.925395.jpg
  4. harleycontracter
    harleycontracter
  5. jick
    jick
    from london
    Like the two previous replies.... Epoxy it all first then put whatever primer you want over that..... Looks like a nice car, it would look even better painted "properly" :)
  6. aerocolor
    aerocolor
    from dayton
    I realize you prefer red oxide color but do use an etching primer as the first coat. Nothing else sticks better.
    I believe DTM Dupont is tintable with a maroon mix color so you might try for that. Start with the white and tint to please.
    I did my roadster in the black and it isn`t flat but closer to the e-coat semi gloss that comes on replacement panels. Very durable and doesn`t chalk like Ditzler DP series primers. Easy to clean too.
      485.9 KB
      512.4 KB
  7. chico'72
    chico'72
    from Belgium
    X2
    Spray a coat off epoxy with a "slow" hardener and there would be no gloss!!
    Sand it a little and spray a color coat finished with a clear coat with a matting paste.
    You will get a suede finisch with any color you like.
    just my 2ct.
    in attach a pic of my motorbike "two tone paint job" suede an gloss.
