History ***RARE Flathead Intakes, Lets see them!***
Discussion in 'The Hokey Ass Message Board' started by mike hamel, Feb 13, 2010.
  1. elmitcheristo
    elmitcheristo
    This is a Hexagon and a very similar looking unmarked manifold. The Hexagon is dated July of 1947 and the unmarked is dated April of 1947. There are a few differences in vacuum ports and most noticeably in the risers, but the overall design is very similar. Just curious if anyone has any info on the unmarked one. Did the earlier ones not have a logo or could it be that someone just stole the design. Anyways, here are the pics:
  2. flatheadkid1
    flatheadkid1
    from OHIO
    elmitcheristo: I have the version with the carb flanges as well. I am certain that these were cast from the same pattern which was modified at a later date changing the carb bases, vacuum ports and oil return. You can see the pattern modification on the later version which stuck out like a sore thumb on some of the poorer castings. I'm kinda partial to the flanged one myself.
  3. Ric Dean
    Ric Dean
    from Central NY
    ... Here’s a Navarro Racing Model 2x2 in a style I have not seen before; because of its higher runners, Non-Gen mount sloped nose and no Breather Boss. I have seen them in a much lower profile & with Carb Bases spaced closer together & towards the back. I’d love to build a 59 AB around this intake.
    … Anybody know anything about this pre 1949 model; how it performed etc?
    thanks, Ric
  4. Michelley
    Michelley
    Rarified Speed:
    85 sets of heads
    120 manifolds!
    No, they're NOT for sale...
    This was our gym for a couple months,
    a couple years ago,
    then we found them a new home.
    They went en masse
    down the road,
    so we could get back to workout.
    Including
    early original pre & post -War
    Eddie Meyer Hollywood, Edelbrock, Edmunds, Evans, Fenton,
    Navarro, Offenhauser, Sharp, Tattersfield, Thickstun, Weiand,
    & the more esoteric
    Douglas heads, Elco Twin heads, Federal Mogul copper heads,
    Harrell Los Angeles heads,
    L & S Racing heads-manifolds, Smith-Jones heads-manifolds,
    Baldwin custom manifold, Jack Henry manifold, Ord intake, Roof intake, E & S blast box,
    Battersby and Davies 2 x 2 intakes,
    Cyclone heads-manifolds,
    plus V860 set ups...
    And so many others!
    (I didn't even mention the six Ardun complete rigs
    because they're not pictured)
    Propulsion envy?
    ~Michelley
  5. unclescooby
    unclescooby
    from indy
    Lousy picture as it was taken in a barn at night but this Jack Henry 2x2 was hiding in the back of an old 50 Ford Woody wagon we pulled out of 48 year barn hibernation last week.
    777
    from Pasadena
    Awesome Pre-War Davies 2X1 manifold with Winfields on a 21 stud with Meyers water pumper heads. All original stuff on Tim's 5W. It's at 9 mins 55 secs or you could watch the whole thing and wait
    <iframe width="420" height="315" src="http://www.youtube.com/embed/kJheak2zuXQ" frameborder="0" allowfullscreen></iframe>
  7. This is a 1933 21 stud. in my 32 Roadster.
      303.4 KB
      312.2 KB
      281.6 KB
  8. 777
    777
    from Pasadena
    I've seen 5 versions of this manifold dated as early as 1935. All 5 versions were cast by Hexagon but only Version 1 is Pre-War it has carb flanges but no name, no vacumm provisions and a taller fuel pump stand that does not work with a mechanical fuel pump. This is the version used on the Ted Horn car.
    Versions 2 & 3 also have carb flanges, version 2 is no name, with small vacuum flange. Versions 3 and later are cast Hexagon, have some type of boss present for vacuum plumbing, usually larger and that may or may not be tapped also the riser heights vary and one version is definitely a marine application.
    The original manifold was designed by D. Sullivan, most likely around late 1934. Urban myth had it designed specifically for Miller/Ford FWD Indy Special. That is now highly disputed and most likely not the case. See an earlier section of this thread for more on that.
  9. banjorear
    banjorear
    Edsel Ford was also working with D. Sullivan for he realized like so many others that by winning races, you sold cars.
    Also, the reason the carbs mount backwards is two fold: One- The Miller cars were front wheel drive so the carbs would be mounted the "traditional" way in a Miller race car. On a normal, rear wheel drive car, they claimed it kept fuel from sloshing around in the bowl.
    There is a matching air cleaner for the Hexagon Tool intakes. I'll dig mine out and try to snap a pict. of it.
    I also have stashed away a Thickstun PM-7, matching air cleaner and matching head covers stashed away awaiting to be put on my pop's '32 Tudor.
  10. Speed~On
    Speed~On
  11. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Oh Whatever. I couldn't even but all the engine stands let alone the damn gems mounted to them.
  12. Fly'n Kolors
    Fly'n Kolors
    OK, now we know where they all went. Call me when you have the garage sale.
  13. Magnus B
    Magnus B
    Any more pics or info about these 2 setups? Looks to be F-heads.
  14. Ric Dean
    Ric Dean
    from Central NY
    … I almost had a Heart Attack! Is this trick Photography; :D can we see some close-ups please?
  15. Ric Dean
    Ric Dean
    from Central NY
  16. Bearing Burner
    Bearing Burner
    from W. MA
    I don't know how rare it is but I have only seen one other. It is a stock cast iron Ford manifold converted to three carb by welding in two cast two barrel pieces with flanges.
    I remember these pieces being in J C Whitney catalogue in the late '50s-early sixties.
  17. GregCT.
    GregCT.
    from CT.
    Bought the book " Merchants of Speed" at Hershey a week ago. Great reading! Tells about the young guys who designed all this stuff. Get a copy.
  18. Modeljunkie
    Modeljunkie
    I'll be the oddball with a 6 banger here, but chrysler long blocks don't seem to be represented in this thread and she is a flathead after all...
    The motor in question is a 52 chrysler 265 waiting to be dropped in my 40 plymouth.
    Nice manifolds folks, keep em coming- I love flatheads!
  19. ChuckleHead_Al
    ChuckleHead_Al
    Man, I love Tall Pre-War Flathead Intakes, The two that standout for me are the Weiand and Edelbrock.. Please keep these pictures coming fellas...
  20. Love seing them on cars, too many of them being hoarded hanging on walls, and not enough on the street.
  21. ChuckleHead_Al
    ChuckleHead_Al
    <iframe width="560" height="315" src="http://www.youtube.com/embed/3jVvgd5wQgw" frameborder="0" allowfullscreen></iframe>
  22. vonpahrkur
    vonpahrkur
    I think i know now why it's so difficult to find intakes to run on my pre-war cars, they're all hanging on people's walls... :(
  23. hotrodderhaag
    hotrodderhaag
    here is my toy...
  24. flatheadkid1
    flatheadkid1
    from OHIO
    The one on the left is called a "Sparks". It is an F-head configuration with overhead intake and stock exhaust through the block. A few of these were made by Norm Frick. They have no water passages in the heads. I have never seen one run. They look cool though.
  25. oldestman
    oldestman
    This threads been quiet too long. Here's a mystery V8-60 intake that has baffled everyone that's seen it.
    The mystery was eventually solved. It's Stelling, designed by Bob Stelling of Stelling & Hellers of air cleaner fame.
      196.5 KB
      200.5 KB
      158.1 KB
      191.2 KB
      210.7 KB
      206.1 KB
  26. RatBoat
    RatBoat
    from Flint, Tx
    I'm looking for a eddie meyer Hi rise or an unusual intake for the wooden boat I'm customizing with a 39' V8 Flathead 239CID. It will stick out above the back deck.
  27. noboD
    noboD
    Did you ever see a picture of Ken Gross's wall of intakes?
  28. Bloody Hell
    Bloody Hell
    from Spring, TX
    Here is my polished Fenton. Have matching fuel log for it too.
  29. titus
    titus
    i found it in a barn just north of st paul mn, guy had passed away so no info where it came from.
  30. titus
    titus
    heres a few ive added to my collection, evans 4x2, fenton 4x2, wieand tall, hexagon tool and weiand 4x2
    downsized_1224031725.jpg downsized_1115032000a.jpg downsized_1115032000b.jpg 2013100295141520.jpg downsized_0115041811.jpg
