random things you remember.
Discussion in 'The Hokey Ass Message Board' started by bigblock225slant6, May 11, 2009.
  1. like the timeing of a flathead 8 to how many pounds of air your cokers use , things that have gotten you through life with your cars.
  2. Boyd Who
    Boyd Who
    Tuesday.
    Well, you did say random! :p
  3. hahahah, not quite THAT random man. lol
  4. oilslinger53
    oilslinger53
    from covina CA
    adjust the needle valve till its closed then open it 1 an 1/2 turns
  5. put some gas in the tank or you will eventually run out.
  6. RichG
    RichG
    15 is too young, 36 is too old, 24 is just right:D
  7. MedicCustoms
    MedicCustoms
    don't ask if you don't want to know the answer, if it seems to good to be true it is.And NEVER mess with a old man in a hot rod!!!!! you'll lose
  8. My 60 Starliner used BF32 Autolites
  9. tighten lugnuts!
  10. CadillacCorey
    CadillacCorey
    Everything bolts onto your car except the exact pile of parts you own.
  11. oilslinger53
    oilslinger53
    from covina CA
    JN659842... the serial # from my schwinn stingray I had when I was a kid... It was stolen 16 years ago, so if anyone sees it, you know what to do. every time I see a schwinn stingray I check the #.
  12. Splinter
    Splinter
    -1 mole of atoms is 6.02 x 10 to the 23rd power.
    -Autolite 605's for most small blocks.
    -The sum of all voltage drops in a curcuit must be equal to the applied voltage.
    -Current is inversely proportianal to resistance in a curcuit.
    -On SH-60B's, is you get an intermittent master caution capsule with no secondary indications, you need to go clean off the intermediate gear box chip detector.
    -The seat pans on an Alfa Romeo Giulietta are 5/8" wider on the driver's side than on the pasenger side. (That's one you don't know till you know it. It's even so random that you don't know you don't know it 'till you learn it.)
    ----Should I go on?
  13. 44-double-D >>>>.
  14. DLX-Fe
    DLX-Fe
    from sacramento
    I just checked the Stingray I bought for $80 last year at a swap meet but its not yours.
  15. r8odecay
    r8odecay
    Avogadro's NUMBER!! :D
    PV=nRT. I never forget that one.
    Or that one.
  16. 38plymouth
    38plymouth
    That metric nuts and bolts have found their way into my SAE bin. Also applies to the supplier.
  17. cornernfool
    cornernfool
    My first piece of ass, over 40 years ago like it was yesterday.:D
  18. BISHOP
    BISHOP
    Righty tighty, lefty loosey.......... unless there is a L on the stud.
  19. First run on a drag strip in my roadster. Pomona, 1961, 110.50, 12.90.
  20. rixrex
    rixrex
    I've learned so much and forgotten so much simply because I didn't practice what I'd learned often enough, make sense?..I thought I was being really cool when I solved a Buddys noisy 235 in his 56 by T-ing off his oil sending unit and running some braided line up to his head to get oil directly on the valve train, later I was looking at the 235 in my 39 Chevy and realized I had done the same thing about 15 years earlier..and as far as weed destroying your memory, I kill on Cash Cab and Jeopardy.....
  21. Baumi
    Baumi
    The 327 in my 56 Chevy I built 6 years ago has L2166nf040 pistons...
    But I don´t remember the part# of the pistons in the engine I built 4 weeks ago, hahaha
    Perfect stat. Timing on my Hot Rod is 11.8° BTDC
    On an old Mercedes 2 liter 4 cylinder,like in my old W 115, warm valve lash is 0.25 mm exhaust and 0.15mm inlet..
  22. Hack Attack
    Hack Attack
    (sbc firing order)
  23. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    the firing order on a flathead 1-5-4-8-6-3-7-2
    I have no idea why that stuck.
  24. 1-5-3-6-2-4. the firing order on every 6cyl i have ever worked on
  25. DocWatson
    DocWatson
    Chin strap,
    Capewells,
    Chest strap,
    Reserve hooks,
    Reserve handle,
    Belly band,
    Leg snaps,
    Suspension hooks,
    Lowering line,
    Lowering device,
    Jettison device,
    Leg strap,
    Centre pack tie,
    Static line stowage,
    Static line clear to cable, hooked on, pin secure,
    Check my back.......
    <O:p</O:p
    <O:p</O:p
    Right one, Right two, Right three.........
    One thousand, Two thousand, Three thousand, Canopy OK.
    High to the left, High to the right, Clear below, pull away to steer.
    60 feet, release equipment.
    30 feet, access drift, select riser and pull down to slow direction of drift.
    R, H, & D.
    Figure eight canopy and daisy chain shrouds, place rig in Para bag.
    Assemble equipment and head for rally point.<O:p</O:p
  26. DocWatson
    DocWatson
    That random enough?
  27. HEATHEN
    HEATHEN
    from SIDNEY, NY
    DR429, DR311, DR70, DR2270P........the Standard Ignition part numbers for cap, rotor, condenser, and points for '57-'74 GM V8 distributors, along with countless other part numbers I looked up in the parts store where I worked 25 years ago.
  28. Little Wing
    Little Wing
    from Northeast
    " oh wait,,this has that clip thing holding that on"..............
    take your time,,and dont try prying it off without looking behind it
  29. LAROKE
    LAROKE
    Gapping plugs with a paperclip and points with a matchbook.
  30. Muttley
    Muttley
    Pickles are on aisle 2-B.
