Ran out of gas, car runs awful now.....
Discussion in 'The Hokey Ass Message Board' started by mack57, Jul 19, 2014.
  1. mack57
    mack57
    Hey all,
    What do I need to do to clean out my carb? I think It sucked up some junk from the bottom of my tank. It runs but, not well.....
    Thanks, Mack
  2. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    Take the carb off, open it up, clean it out, blow out the lines, and put on a GOOD filter!
  3. Belchfire8
    Belchfire8
    I have used the old rag over the carb trick very successfully several times. Rev the engine and then smother the carb with a rag while trying to keep it running, I don't let it die, take the rag off before it stalls. I usually repeat a couple times.
  4. Do you not have a inline filter? HRP
  5. belchfire8.....2x
  6. gnichols
    gnichols
    from Tampa, FL
    Ifn the Belchfire trick doesn't keep everything open in the long run, it just might be time to clean out everything, from the tank, to the filter(s), pump, regulator, etc., for complete piece of mind. Gary
  7. tfeverfred
    tfeverfred
    Rebuild carb. Replace those old fuel lines and filters. Flush tank.
  8. M224SPEED
    M224SPEED
    from Missouri
    What Fred said,otherwise it will just happen again, right?
  9. 49ratfink
    49ratfink
    could be something in the carb or it could even be something stuck in the lines or a clogged filter.
    first thing to do would be a new filter and blow out the lines. then clean out the tank so it does not happen again. Ihad problems a while back with my old Dodge. when I took the sending unit/fuel pickup out of the tank it looked like something from the Titanic. I'm surprised the car ran at all with all the crap in the tank.
  10. Just open the carb up and clean it out, its not brain surgery.
    bchrismer likes this.
  11. mashed
    mashed
    from 4077th
    Exhaust all possibilities. Then play stumped.
  12. richie rebel
    richie rebel
    ran out of gas????
  13. Andy
    Andy
    I had an early VW. No gas gauge. You would throw a lever to change to a deeper pick up in the tank. If I ran out at high? speed, the engine would run bad for a while and then clean up. I never knew if it was plugs or valves.
  14. hdman6465
    hdman6465
    You do realize that you pickup fuel from the bottom of the tank ALL the time , don't you?
  15. This is good enough to get it home, I've had good luck with it though. I still recommend taking the top off the carb (may as well rebuild it..) and put a good inline gas filter in. I like those red Holley can ones with the replaceable filter.
  16. mack57
    mack57
    Thanks All!
    It's a new Edelbrock carb with inline filter. The gas gauge is not working. Ran GREAT until I ran it dry. First I'll swap out the filter & clean out the tank.
    Good point, it always picks up from the bottom of the tank First.... Wonder why this didn't happen earlier then?
  17. D-man313
    D-man313
  18. did it backfire through the carb when it ran out of gas? blow off a vacuum line? power valve?
  19. mack57
    mack57
    No, no backfire... But, I'll check the vacc lines for sure! Thanks!!
  20. How long has the car been on road? HRP
  21. mack57
    mack57
    2weeks or so...
  22. I am sure their is a good shop close to that can help
  23. B.A.KING
    B.A.KING
    ME personally, I would run a can of sea foam thru it , 1st.
  24. mack57
    mack57
    Fuel filter changed, running better.
