Technical Radiator fan question
Discussion in 'The Hokey Ass Message Board' started by Spike788, Jul 3, 2024.
  1. See attached pictures. Had to remove radiator fan and in doing so one of the mounting studs broke off so upon reinstalling I resorted to using zip ties to secure it on the passenger side. Will these hold? They're not going through the core itself. I've no doubt they will hold the weight of the fan but is there any concern that the zip ties will melt being so close to the radiator? Sorry if it's a dumb question. They're rated for up to 185 F. I know they make those plastic fan mounts that go directly straight through the core so I'm wondering if these will withstand the heat?
  2. Oneball
    Oneball
    They’ll cope with the radiator’s heat.
    You can quite successfully weld broken plastic using a soldering iron and zip ties as the filler rod.
    dana barlow, JohnLewis and Bob Lowry like this.
  3. Acres
    Acres
    from Sweden
    They will hold, but use double of them as a backup, there is quality problems with some of them.
    Sometimes they snaps off just trying to use them
    Bob Lowry and RICH B like this.
  4. How about stainless steel zip ties, those ain't going anywhere....
    JohnLewis likes this.
  5. KevKo
    KevKo
    from Motown
    The plastic ones will eventually get brittle and break.
  6. BJR
    BJR
    Use traditional zip ties!
  7. JohnLewis
    JohnLewis
    Mechanics Wire?
    David Gersic likes this.
  8. 19Fordy
    19Fordy
    Use Bob's stainless steel zip tie suggestion.
    You could also make new metal holding brackets and pop rivet them to the shroud.
  9. I ended up using the stainless steel ties. Thanks fellas. Appreciate it.
    bobss396 likes this.
