Technical Radiator Differences
Discussion in 'The Hokey Ass Message Board' started by FireTruckCS, Jun 1, 2020.
  1. FireTruckCS
    FireTruckCS
    I'm in search of a '35 Ford heavy duty commercial truck radiator. Can anyone confirm if the '36 Ford heavy duty commercial truck radiator cores and tanks are the same as the '35? My understanding is that the only difference are the side brackets and that the core is the same. Does anyone happen to have a '35 Ford 1.5 ton commercial radiator they'd like to sell? Condition does not matter.
  2. AVater
    AVater
    1. Connecticut HAMB'ers
    A few things here:
    “Commercial” typically means the 1/2 ton kinds of trucks like pickups
    I’m not sure of differences between commercial and 1.5 ton trucks With respect to radiators. I believe they both use the same pan below that has two different crank holes
    ‘35 and ‘37 Radiators are definitely different but not sure of differences between ‘35 and ‘36 except the grill is much deeper on the ‘36
    hope this helps
