Hot Rods Rad cap
Discussion in 'The Hokey Ass Message Board' started by sdluck, Jun 3, 2024.
  1. sdluck
    sdluck
    There used to be a rad cap with with an anode in it to reduce galvanic corrosion,any body use it?My engine and heads are aluminum 50/50 coolant and a trickle charger @ times..
  2. DDDenny
    Subscribed!
  3. Bandit Billy
    Bandit Billy
  4. DDDenny
    Considering what I paid for my bare block alone, I might get a couple of them and change them once a year.
    You ask, is your car on the road yet, and I say "your kidding right"!
    Dave G in Gansevoort likes this.
  5. Oneball
    Oneball
    How’s that going to work? It’s not electrically connected to the block/heads
  6. sdluck
    sdluck
    thru the coolant
  7. Oneball
    Oneball
    Anode and cathode need to be electrically connected by a wire or direct contact. Just plopping two bits of dissimilar metal in a bucket of water isn’t going to stop the one corroding.
    Wanderlust likes this.
  8. Budget36
    Budget36
    Won’t it lay on top of the tubes?
  9. DDDenny
    Anodes in electric water heaters aren't electrified.
  10. Oneball
    Oneball
    They’re bolted to the metal case, which is an electrical connection. Didn’t say they need to be electrified.
  11. Phil P
    Phil P
    I would say it's connected to the cap which is screwed to the rad. Now if the rad is isolated by rubber mounts the rad is the only thing protected.
    Phil
  12. stuart in mn
    stuart in mn
    What is your radiator made of? If it's aluminum as well along with the block and heads, there shouldn't be any galvanic issues.
  13. sdluck
    sdluck
    Original I believe
  14. DDDenny
    German silver and other tidbits.
  15. Beanscoot
    Beanscoot
    Why is the anode coated with, or made of, yellow plastic?
  16. I use an anode in my radiator petcock position. After 3 years I decided to replace it, picked up some marine anodes on eBay. So I take the "old" one out, it was still 100% all there. I replaced it anyway.
