Art & Inspiration QUICKCHANGE rear ends
Discussion in 'The Hokey Ass Message Board' started by Frames, Apr 3, 2020.
  1. Frames
    Frames
    F. Y. I. 201 also know as a V-8 QC. It is based on the 39-48 Ford car R&P. 6 spline. Good for up to about 300 HP if used with slip in axles. 301 also know as a champ QC. Good for 800HP. It is based on Ford 3/4 ton truck 38-41 R&P. 10 spline. pictured 301 with 38-52 3/4 ton LEFT SIDE steel side bells with 9" ends. 2nd picture. Quite a bit of difference in size. 3rd picture . 201 with 10 bolt car housings and axles. 4th picture. 301 with H852 side plates to use 10 bolt car housings. Ends welded on for wide 5 racing hubs. 5th picture. 301 with aftermarket side bells. Sorry. Computer decided to put 5th picture 1st. 11 BOLT 002.jpg Trans sprint 039.jpg halibrand-----frankland-----winters 001.jpg -----CALANEGO    4-28-14 001.jpg varius quickchange 007.jpg
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Dennis, let me help you out here:
    201 also know as a V-8 QC. It is based on the 39-48 Ford car R&P. 6 spline. Good for up to about 300 HP if used with slip in axles. 201 with 10 bolt car housings and axles.
    301 also know as a champ QC. Good for 800HP. It is based on Ford 3/4 ton truck 38-41 R&P. 10 spline. pictured 301 with 38-52 3/4 ton steel side bells with 9" ends.
    Just to clarify: 201 and 310 designations refer to Halibrand part numbers. Each manufacturer has it's own names for these units. The last picture is a Winters Heavy Duty.
    loudbang and kadillackid like this.
  3. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Dennis,
    In your picture of the two side by side, what are the bells on the 201? I've seen that 6 rib style on the larger units but not on a V8.
    loudbang and zorro4153 like this.
  4. Jalopy Joker
    Jalopy Joker
  5. I yearn for one of these, great informative description guys, thanks :cool:
    Barrelnose pickup and loudbang like this.
  6. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Not exactly sure of why @Frames started this thread. He's seen and done it all.
    kidcampbell71, Petejoe and loudbang like this.
  7. Look in the classifieds.:rolleyes:
    kidcampbell71 and egads like this.
  8. oldfordtin
    oldfordtin
    Halibrand made them for the 201 as well IMG_20191115_101023_127.jpeg Screenshot_20191016-190650.jpeg
    Sent from my SAMSUNG-SM-G925A using The H.A.M.B. mobile app
  9. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I know about the ones in your pic but they are not the same as the ones in Frames post.
