Quick Shoebox Ford Question
Discussion in 'The Hokey Ass Message Board' started by G V Gordon, Dec 29, 2009.
  1. G V Gordon
    G V Gordon
    from Enid OK
    What is the hub to hub width on a stock shoebox Ford front end?
  2. hotrod-Linkin
    hotrod-Linkin
  3. G V Gordon
    G V Gordon
    from Enid OK
    Thanks, looked in my old Motors book last night but only found wheelbase. Getting ready to order a straight axle.
  4. hotrod-Linkin
    hotrod-Linkin
    gotta see that gv!!
  5. G V Gordon
    G V Gordon
    from Enid OK
    The victim.
    I picked this car up because it is a dead ringer for my very first car. My history notebooks in highschool were full of scketches of what i would have liked to do with my car but alas a poor Oklahoma farm kid could only dream. So now maybe i can build my little "gasser" shoebox some 40+ years later. lol
  6. 19Fordy
    19Fordy
    Is "tread" the same meaning as "tread width"? I always thought "Tread Width" was the horizontal distance between the vertical centerline of the front or rear tires. The reason I ask is that my 49-51 Mercury Manual says the front "Tread" for '49-51 Mercs is 58 1/2 in. and the rear "Tread" is 60 in. But when I measure the distance between the wheel mounting surfaces of the rear wheels it is exactly 61 1/4 in.
  7. Greezy
    Greezy
    Looks like a good start GV. What engine are you going with?
  8. G V Gordon
    G V Gordon
    from Enid OK
    A (gasp) SBC. I have it already and have a B&M Street charger for it so that gets the nod. Going with what I have. Saved the '62 Corvair buckets for the interior. Using a 4" dropped axle because I don't like my gassers sitting a mile high, radiused rear wheels and slicks.
  9. straykatkustoms
    straykatkustoms
    SSSSHHHHHHHHHHHWWWWWWWWWWEEEEEEEEEEEEEEETTTTTTT!!!!
    Good luck with the project.
    Happy Trails,
    Mick
  10. G V Gordon
    G V Gordon
    from Enid OK
    Mick, I figured I would catch hell from you because it wasn't going the custom route. lol Thanks, money and time will dictate how fast it evolves.
  11. hotrod-Linkin
    hotrod-Linkin
    depends on wheels you are using. the factory measurements were taken using stock wheels.
  12. straykatkustoms
    straykatkustoms
    I thought that you would "Gass it" for a while then phase "b" you would start
    converting it into a kustom. Most important thing to have fun with it!
    Happy Trails,
    Mick
  13. Hnstray
    Hnstray
    from Quincy, IL
    The "tread width" or "track" is center to center of the tires when mounted on OEM wheels.......that is not necessarily the same distance as the wheel mounting surface to wheel mounting surface, because wheel offset can be zero or negative or positive. Any of which, except 'zero, affects the "tread width"
    Ray
  14. 19Fordy
    19Fordy
    12/29/09 Just curious. What size rims are on the car and what vehicle did they come off of - if you know. Also, what is the bolt pattern? Thanks, Jim
  15. G V Gordon
    G V Gordon
    from Enid OK
    not sure and the car isn't here. I can check later on if you like. I think they may be late Thunderbird.
