questions about 1962 6cyl impala's
Discussion in 'The Hokey Ass Message Board' started by wrong generation, Feb 10, 2013.
  1. wrong generation
    wrong generation
    from new jersey
    what would be the most likely rear gears found in a 62 impala that came with the 230 6-cyl with a powerglide ?
    being that the 230 6cyl had 135hp/220tq gross rating. what would the net rating be ?
    also what would the car get for gas milage ?
  2. reece
    reece
    from NC
    I pulled a 3.36 center section out of 4 door 62 6 cyl. Several years ago. Pretty common ratio and found in a lot of the 283 cars as well. As far as mileage and hp I have no idea.
  3. gas pumper
    gas pumper
    Different areas had different standard rear ratios. Or dealers ordered ones that "fit" the local area. Here in NJ 283 PG cars late 50's early 60's were mostly 3.08. Sticks 3.36ish. Station wagons 3.55 and 3.70. Six cylinders might have been one step lower all across. PA was different (lower). And I'm sure the flat middle country was different again (higher). Also never saw an OD here in NJ on the 50's 60's stuff.
  4. 5559
    5559
    from tn
    more than likely a 3.36------6cyl 3 spd 3.55
  5. lawman
    lawman
    Great "tec" Guy's !!!!
  6. 49ratfink
    49ratfink
    wouldn't 62 still be a 235?
  7. CNC-Dude
    CNC-Dude
    Stovebolt equipped I believe, not 230.
  8. jcmarz
    jcmarz
    from Chino, Ca
    Correct! 230s came out on the 63 models
    My mistake, 62 was the first year for 230s . I got the years mixed up. Sorry about that
  9. wrong generation
    wrong generation
    from new jersey
  10. gas pumper
    gas pumper
    Me too, up to about 4 years ago. Best part time job there is. No one has high expectations of you and the world thinks you're an idiot. And the tips were great.:)
  11. wrong generation
    wrong generation
    from new jersey
    lol i wish i did it part time. but for a 2nd full time job it can't be beat. that being said and having barly anything to do at night except for think. based on other numbers from when they switched from gross to net. would it be save to say the car only has 100hp-175torque ? still trying to figure this stuff out for sure.
  12. JollyGreenGiant
    JollyGreenGiant
    The last year for the 235 engine was 1962.
  13. Fat47
    Fat47
    Last Sept. I picked up a 60 wagon---235 three speed----in Washington and drove it back to Indianapolis. Averaged between 20 and 22 MPG over a 2500 mile trip.
  14. models916
    models916
