This will be my FIRST experiance with them on this current project some things I need to Know. 1: is there a way to Baffel them? 2: is there a decent looking way to run them with the pipes as designed on an open car ? 3: how large is the exhaust outlet for running said pipes? 4ics of your set up?
Do a search I think around one of the techweeks about a year back someone posted about using V-Dub baffles like they use in the stinger exaust use on he dune rods. I've alway thought that a disc difuser set for Supertrap muffler would work well. Or dyna tech makes a cone baffle that will work in one. They're not too pricey.
[ QUOTE ] I've alway thought that a disc difuser set for Supertrap muffler would work well. [/ QUOTE ] That's along the lines I was thinking. What would you then do to block the Pipe end? Obiously a rubber plug ain't gonna work.....lol
A metal plate like goes on a Lakes pipe. Only it won't have to be fancy because it points down right? The disc kits will run you about 60.00 apiece for your setup. The Dyna Tech cones run about the same price and they won't show on the outside. But they'll have a little more bark (race stuff).
