Projects [PROJECT] Laidout53 Part II
Discussion in 'The Hokey Ass Message Board' started by HarborKustomSpeedShop, Oct 11, 2010.
  1. Can't wait to see those speed holes in the shifter!
  2. thank man
    Thanks!, however i wish i had some customers rides to work on...
    Wow Thanks man, its rated for 3/16" single pass. All my stuff is 3/16" and thinner. I would say you would be fine if you did two passes. Beveling the edges where you can will help alot too.
    Thanks guys!
    Thanks Bud, ya if your ever on this side hit me up!
    Thanks me too! as soon as i get some steel, im going to get it cut out.
  3. Making the rear fenders the same as the fronts looks real good ehhh??:D I can't say anything because if you do it, you will put my hack job rears to shame...
    Here's a little inspiration, not that you need it!
  4. Thanks, trucks looking good Mike.
  5. Thank you, and the same to you!
  6. nowhereman
    nowhereman
    from illinois
    man i love this build:D
  7. Thanks man, Me too...;)
  8. garagebuilt51
    garagebuilt51
    wait... this is a bad ass build,... but you wouldnt brag to some minitruckers about it would you? love the sheet metal work!
  9. Thanks... um I dont brag about anything i can do, theres will always be someone who does it better. I hope i dont come off as if i bragging? All im doing is sharing my work for others to see and give me feed back on how i can improve and for ideas that i havent though of.
    Justin
  10. Don't hold back, I think we all glean a little from each post/thread, I know I have.
  11. nowhereman
    nowhereman
    from illinois
    you don't need to brag the work speaks for itself!
  12. garagebuilt51
    garagebuilt51
    it was a joke about another forum.... not a diss. once again love the work.
  13. Yes of course, but not in a bragging way. Its always nice to hear good comments about your own work from your peers, especially with the amount of talent thats on the forum!
    Thanks again for the kind words man!
    Sorry it just hit me wrong, had i know it was a joke i would have said something witty back...LOL
    No harm done and again Thank you!
  14. ph8ed4life
    ph8ed4life
    from AZ
    Coming from someone who has attempted a full custom frame, I must say this is amazing work ans congrats!
    Makes me want to dust off the project and get back on it!!
  15. FOOFZ
    FOOFZ
    from houston
    nice work what wall thickness is your 2x6 on the frame.
  16. Thanks man!
    Thank you, the frame is all 1/8" wall.
  17. Ole_Red
    Ole_Red
    from 206, WA
    Will you be hitting Puyallup this year with the 53?
  18. I will be there but not in the dodge, Next year i should have it there.
  19. cmarcus
    cmarcus
    Anything new?
  20. linkstar69
    linkstar69
    Great fab work.
  21. bigpokie
    bigpokie
    Happy 4th ! Any updates. Something has to have changed in 2 months. Or just post pics of it sitting. I dont mind
  22. nowhereman
    nowhereman
    from illinois
    :)waiting patiently:D
  23. Wow I haven't updated this in Months!
    Well good news here is an update.
    So the next order of business was to tub the firewall...
    and done with some clearance...
    So after that I hade to move the gauge over about 2 3/4" to center up with were the steering column would be...
    Then I pushed it out side to get a good look at everything...
    I decide to use the button for the glove box, so I centered it to make it look right...
  24. Now it was time to start on the front bumper, man this was a big job for just a bumper. Anyways I cut up the front and rear bumpers for a 51 ford car. the ends are from the rear bumper and the middle section is the front. I wanted the contour to run full length.
    Here are the pictures
    the parts needed...
    tacked
    once welded you can see the ends don't line up
    after some cutting and grinding they do
    Next it was time to make mounts
    and mounted and smoothed
    Continuing with the frontend I started to modify the 54' ford headlight bezels so the were removable. First I TIG welded a tab of stainless to the backside on the bottom to hold it in.
    then I bent up a mounting tab for the top for the screw to go into
    together, had to add a tack on either side of the tab to keep it from moving around (still need to counter sink the screw hole a little more)
  25. Now I decide to mount the steering column. First up I made a steering column clamp mount
    welded one half to the dash
    bolted together
    and seen from the engine bay
    and lastly I fab a little panel to hold the key switch and headlight switch
    Ok now this is up to date! Ill try to not go so long next time...
    Thanks for looking, let me know what you all think?
    Justin
  26. BIGREDTODD
    BIGREDTODD
    It's amazing to me how the (heavily modified) '51 Ford bumpers seem so consistent with the grill bars. Both in profile, and proportion to each sequential bar. Great call.
    All the details are staggering. Did you ever imagine it would evolve into something like this?
  27. Apittslife
    Apittslife
    Beautiful work as always!
  28. IronTrap
    IronTrap
    Love it, turning out great!
  29. JoeyP.
    JoeyP.
  30. Can't wait to see this done.
    We've said it before, but I'll say it again...you have some incredible skills and your eye for design is amazing too.
