Hot Rods Preparing EDP Coating for paint
Discussion in 'The Hokey Ass Message Board' started by old_chevy, Jun 10, 2025.
  1. old_chevy
    old_chevy
    from USA
    I know some say to remove the EDP coating to bare metal. I tested the EDP coating and it appears to be durable. What should I use to scruff the EDP coating and then apply paint?
  2. Rich796
    Rich796
    If you're scuffing and want to go directly to paint. Like the jam areas on a DD/GG. Scuff with gray scotch bite.
    If you're painting the exterior on a DD/GG, DA 320 ( with an interference pad ), seal, BC, CC.
    If you're painting something nicer. DA 320 ( with an interference pad ), epoxy, 2K filler/surfacer, block sand, seal, BC, CC.
    That is a generalized procedure . . .
  3. ronzmtrwrx
    ronzmtrwrx
    What you really need to do is consolidate all your questions that you’ve created individual threads for into one, maybe a build thread of what you’re building if it’s not off topic. I think you would get better results. Not trying to be rude, just giving you my honest opinion.
  4. Read the tech sheet for the product used first
    painting directly over E -coat is a no no in my world. Nothing chips easier than paint directly over e-coat.
    if no damage on the panel, I clean, sand with 320 followed by a red scuff pad then clean again.
    seal with a proper sealer. If lots a bare metal after sanding, a DTM product needs used. (Direct to metal) again, read the tech sheeets for the products used
    Then paint according to the tech sheet
    Just Gary and lostone like this.
  5. Bandit Billy
    Bandit Billy
    I never primer over a shiny surface. Sand it, scuff it, get some traction.
    Just Gary likes this.
  6. DDDenny
    Wow, that's quite a portfolio of threads!
    Moriarity likes this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    I am going to ask you this again, maybe you will answer this time. What kind of car are you working on?
    It would sure be far more productive and interesting for the members here helping answer your questions if you had a build thread with pictures showing what you are doing. it could be a thread where you could ask peoples opinions on how to do things rather than having dozens of individual threads asking for help on every possible step of a restoration
  8. alchemy
    alchemy
    75 Datsun
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    really? He actually said that? If that’s true he should just start a build thread in the off topic forum. 46 individual threads on every single detail of a restoration is ridiculous
    Just Gary, 57 Fargo and K13 like this.
  10. alchemy
    alchemy
    No, just kidding.
    Moriarity and Just Gary like this.
  11. Read the tech sheet
    read the tech sheet
    read the tech sheet
    read the tech sheet
    or tell us what product you are using and we will read the tech sheet.
    you get lots of questions answered by the tech sheet.
    we don’t mind interpreting the tech sheet
    read the tech sheet
    oldsmobum likes this.
  12. alchemy
    alchemy
    What’s a tech sheet? I thought real hot rodders threw away the instructions.
  13. A product use sheet that answers 90% of the paint questions asked
    The other main question:
    What crap are you spraying.
    Torque specs for paint
    without that info it’s kinda like asking what my timing should be and no other info given.
