ALREADY IN UK!!!!! SO YOU HAVE NO IMPORT CHARGES TO PAY!!!!! Powermaster MasterTorque Starter 9604 UK. Ford V8 289 / 302 / 351W / 351C Manual Transmission Brand: Powermaster Manufacturer's Part Number: 9604 Part Type: Starters Product Line: Powermaster Mastertorque Starters UPC: 692209007081 Starter Style: Mini Denso Starter Finish: Natural Adjustable Mounting Block: Yes Starter Rotation: Standard Maximum Recommended Compression Ratio: 14.0:1 Gear Reduction Ratio: 3.25:1 Mounting Block Material: Billet aluminum Quantity: Sold individually. More than one available Notes: This starter features the infi-CLOCK mounting block. Local Pickup: Buyer can collect from CR2 Surrey area. With their gear-reduction drives, heavy-duty PowerMaster Mastertorque starters really crank out the power--180 ft.-lbs. of torque. So they can handle engines with compression ratios as high as 14.0:1. If your stock starter clears your oil pan, they will, too. Some will also clear kicked-out pans. These starters can be mounted in multiple orientations, and some will work inverted, with the solenoid down. They feature a black wrinkle finish. Sent twice by mistake from MacsAuto Parts (Ecklers) on 10/9/2018. Brand New in box Can be connected via external solenoid or direct to its own internal solenoid.
