Hello, this is going to be the first time Porting a cylinder head. The head has these metal rings that couple both inlet ports from the head to the manifold. I was wondering if I should ditch them and enlarge the ports or just leave them in and leave the ports alone. I have two 223 motors. The one I’m building was born .060 over and it has these rings while the other motor doesn’t. Any help would be greatly appreciated. Heres some pictures regarding the coupling rings. 02BB075F-F232-4A0A-849A-7DA259F56530 by Duke_62 posted Jul 19, 2020 at 4:11 PM 83AEE1D7-A331-4601-9D6B-8B5FA98B0C25 by Duke_62 posted Jul 19, 2020 at 4:11 PM 0C84C86B-2735-4D46-90B6-48E8CDDB3E4D by Duke_62 posted Jul 19, 2020 at 4:11 PM 73E9EB50-D606-4BBB-BB5C-CCA5C94C81C2 by Duke_62 posted Jul 19, 2020 at 4:11 PM 29D48DCC-215A-4FC3-80EE-0D43F445EF36 by Duke_62 posted Jul 19, 2020 at 4:11 PM
i dont know anything about that motor, but generally those rings are a good thing to help avoid intake leaks, and manifolds sometimes sag and warp over time. the rings keep it all straight. i would think you can find some better use of time than trying to port a 223!
Thanks for the info, and I think building up the 230 would be a great start for me until I’m done with college and have a budget I could actually spend.
They locate the intake on the without them it is very difficult to line up the intake ports. BlueFlame Chevy 6 use them as well, I had a full port and polish on my 261 head the alignment ring relief were left alone. I don't have any good photos of the ports. Why not try to come up with a 262 the big truck version of the 223?
Thanks for the pictures, I think I’ll leave the rings on and port out anything that is in the way. It’s hard to find a 262 around here, and if I get the chance in the future to do an engine conversion I’ll probably be looking for a 351.
3 angle valve job and clean up any roughness in the ports. Don't go too smooth on the intakes you want a little texture to vaporize fuel.
As per Bill "Grumpy" Jenkins book: The farther away from the valve seat you get the less effect your porting efforts will have. Concentrate on the valve seat and valve bowl area and just blend the port by the rings enough to eliminate any interference obstructions.
I cleaned up the undercut on the valve seats, it’s really difficult to do it perfectly because of the angle the valves have. I separated the adhesive on two of my carbides from catching around and on the base of the valve guide, but luckily the seats were not touched. Thank you for the pointers.
