Customs Pontiac confusion
Discussion in 'The Hokey Ass Message Board' started by mciron, Dec 18, 2021.
Tags:
  1. mciron
    mciron
    Where can I get hydraulic lifters for a 1955 Pontiac 261 six cylinder? Also needed is a heater temperature control valve, any help much appreciated. Maciron9
  2. jimmy six
    jimmy six
    Should be the same as the Chevrolet 235’s from the 52 powerglides up thru 1962. Check with Melling or Egge. Not sure if everything isn’t Chinese now.
    If the heater control valve is vacuum operated a 55-56 Ford will do. They are available. If cable operated an inline one from Vintage Air and be easily adapted.
  3. fyrffytr1
    fyrffytr1
  4. The Canadian 261 used in Pontiac’s up here as a “ premium engine” is the same as a 235/261 used in chevies in the USA .
    when I built my 261 I got them along with everything else through Eggie (sp?) machine .
  5. stuart in mn
    stuart in mn
    VANDENPLAS likes this.
  6. mciron
    mciron
    Just checked them out, no lifters listed
  7. connielu
    connielu
    1. A-D Truckers
  8. Budget36
    Budget36
    Might I ask the need for lifters? I/e are yours bad, worn, solid or missing?
  9. rockauto
  10. Beanscoot
    Beanscoot
    Howard's Cams only list mechanical, although the image appears hydraulic.
    No listing that I could find at Rockauto.
    The bottom could probably be reground at a camshaft grinding shop, and with a good dismantling and cleaning, lifters are usually fine.
  11. stuart in mn
    stuart in mn
  12. connielu
    connielu
    1. A-D Truckers
