poly motor carb info needed
Discussion in 'The Hokey Ass Message Board' started by goon56, Dec 18, 2010.
  1. goon56
    goon56
    from new jersey
    workin on a late series 1955 dodge truck. still can't pin point if it's a 260 or 270 poly. have read and heard the dodge did the 260 and that plymouth did the 270 and visa versa. either way, the motor has been bored 30 over, and the heads have had been ported and had a three angle valve job. stock cam. currently running the stock 2bbl ww stromberg, and it seems like it could run better. anyone know what the stock cfm is? and anyone have any ideas on a better or slightly bigger two barrel four bolt carb i can use for my engine set up. engine is assumed to be around 200 210 horse in this configuration
  2. dave s
    dave s
    from 55 it should be the 260, i think the 270 was 56. i had a two bbl 500cfm holley on a 56 270 and it ran great. i had to use an adapter though... i also had a stock 55 260 with dual 2bbls, and it ran fantastic with the two carbs.
  3. goon56
    goon56
    from new jersey
    the owner would like to run the dual carbs someday, but the intake and extra carbs aren't in the cards right now. 500 cfm seems like a bit much to me though.
  4. George
    George
    260 is a Ford, it'd a 259.
  5. Willy301
    Willy301
    can you rejet the carb on it to see if a bit more fuel helps?
  6. carbking
    carbking
    The passenger 270 utilized a 4 barrel that was somewhat larger than the 500 CFM two barrel. Remember how CFM is rated:
    http://www.thecarburetorshop.com/Carbshop_carbsizesandCFM.htm
    Jon.
  7. 73RR
    73RR
    Use a B&B off of a 318. Plenty of air.
  8. goon56
    goon56
    from new jersey
    good info. anyone know what the cfm of the stock carb i'm using is?
  9. goon56
    goon56
    from new jersey
    b&b off a 318?
  10. 73RR
    73RR
    Carter Ball and Ball. Basic 2-bbl on most 318's in the 60's and 70's
  11. George
    George
    Dodge & Plymouth had 241(Dodge hemi only) & 270, 259 is Plym only in cars & Dodge in trucks.
  12. goon56
    goon56
    from new jersey
    so anyone know what the stock 259 poly carb cfm was?
  13. 35desoto
    35desoto
  14. carbking
    carbking
    Guesses abound, but the actual number was never published.
    Jon.
  15. Abomination
    Abomination
