Technical placement of residual valve with respect to placement of pressure activated brake light switch?
Discussion in 'The Hokey Ass Message Board' started by SDS, Aug 24, 2021.
  1. SDS
    SDS
    Is it acceptable to have a pressure activated brake light switch between your master cylinder and a residual valve?
    I'm pretty sure you might have problems if you had the brake light switch plumbed between the residual valve and the brake cylinder/s
  2. BJR
    BJR
    That sounds like the correct place to put it to me.
  3. squirrel
    The pressure switch needs a lot more pressure than the residual valve will hold, to activate it.
