Pilot bushing removal--what's the trick?
Discussion in 'The Hokey Ass Message Board' started by earl schieb, May 23, 2005.
  1. Something about packing it full of grease and driving it out with a socket?? :confused: Sorry, I forget stuff....:(
    I'm a body shop guy, not a mechanic:p Somebody help me before make a mess....
    I'd buy a new one, but I can only imagine the look on that teenage counterguy's face at the local auto patrs store when I ask for a crankshaft pilot bushing for a 3-speed Cadillac :eek:
    thanks y'all
  2. Fat Hack
    Fat Hack
    from Detroit
    You can pack it with grease then drive it out with a rod that fits snuggly into the hole, or you can do it by wadding up wet paper towel and stuffing it into the hole and behind the bushing itself.
    I had to use grease AND wadded up dry paper towels to pop the one out of my old Vega motor! For lack of an appropriately sized dowel rod, I put a deepwell socket of the right size onto a 3/8" drive extension backwards and used that to mash the grease and towels enough to knock the bushing out.
    Not fancy or high tech, but it works!
  3. oldspeed
    oldspeed
    from Upstate NY
    The trick is: find a short socket that fits into the existing bushing kinda tight you dont want a lot of clearance ( I use a piece of stock from a cut off bolt for my ford) fill the existing bushing with grease, turn the socket backwards on an extension and hammer it in, the grease will flow behing the existing bushing and you and the hammer are being the hyd. piston forcing it out. It actually works. but the fit has to be close. Good luck should work.
  4. That's the direction I was headed.....
    Thanks Greg---you're my NEW best friend! :eek: :D
  5. Why pull it if you're going to reuse it?
  6. Petejoe
    Petejoe
    from Zoar, Ohio
    I have been meaning to make a tool that slips into the Id opening, opens up past the bearing and has a weight on it that can be rammed out.
    i have tried the grease trick. I have never has luck with it and end up getting a chisel and hammer and taking it out piece by piece. Of all jobs, I hate this one the worst.
    The problem I see with the grease trick is you really never find the diameter of insert at the right size and grease ends up slipping out past the insert.
  7. uhhh you TOO oldspeed
    now I have TWO new best friends :p
    Thanks a bunch guys.
    mid-tenn mike
  8. Not reusing that engine....it's locked up tighter than a tick on a hound dog.
    I'm hanging the 3-speed on my good 331.
  9. Fat Hack
    Fat Hack
    from Detroit
    That's where the paper towel wadding comes into play...you'll still get grease oozing out, but the towel helps hold enough in there to do the job. Most times, you have to pound it in, re-pack the hole and pound it in again and again until the bushing moves. It can be slow and tedious (if your bushing is as stubborn as mine was), but it will work...and it will get the bushing out unharmed as a nice bonus!
  10. blackesthart
    blackesthart
    from s.d.
    buy a new bushing
    03GMCSonoma likes this.
  11. that tool is being made , it's called a pilot bearing puller..i have one and use it , i too have never had much luck with the grease method
  12. junkman104
    junkman104
    I have had good luck using a bolt that fits inside the bushing then wraping masking tape around the threads until its a snug fit. fill it with grease and hamer the shit out of it. So far its worked all the time.
  13. Clark
    Clark
    There is another trick of usings wet toilet paper(preferabley new!) Wet the TP jam it in the bearing use a rod that fits tight into the bearing and tap it in with a hammer. It may take a try or two but I have done it before. It works on the same idea as the grease just a little easier to clean up :D
    Clark
    PS...no I'm not kidding
  14. oldspeed
    oldspeed
    from Upstate NY
    I cheat I have a lathe and some CRS grease works every time.
  15. Gotgas
    Gotgas
    from DFW USA
    LOL at you guys saying to use a socket or something.
    Just use the right clutch alignment tool. It is sized properly to the throwout bushing/bearing and you're gonna have to have it to line up the clutch disc when you tighten the pressure plate. :confused:
  16. repoman
    repoman
    Yeah, What he said.
    It never took me more than 15 seconds to get one out.
  17. If it's the original BUSHING, prolly brass... do the trans & engine a favor and replace it with a sealed pilot bearing. If your local parts store doesn't carry one...then try a local bearing store. Most of them have bearings in all sizes and types.
    To get that brass bushing out in 1 piece...use some SoK! Penetrating Oil (Best on the Planet) and a small slide hammer. Take that bushing to the bearing shop and tell em to match it with a sealed bearing.
  18. yorgatron
    yorgatron
    i agree.
  19. New bushings are cheap. Buy a new one.
    I use this method:
    Get a big fatassed bolt... I think 3/4" head with a 5/8" thread... Put it on my impact and drive it into the brass bushing... it threads itself into the soft brass and goes until it hits the back of the crank. Once it hits the back of the crank then the the bolt can't go further so the bushing starts to climb up the threads until it pops out. After it's out, throw the bolt and bushing in the trash. The longest it took me was like 10 seconds.
    This is for a Chevrolet so... I don't know what the rest of you guys got.
    Travis
  20. Sticher1
    Sticher1
    from Ct
    Like Texashardcore says put in a sealed bearing I did its the only way to go my 5cts worth
  21. old beet
    old beet
    I've cut about a foot off a broom handle, sanded to fit and used the grease trick............It works.........OLDBEET
  22. BigDdy31
    BigDdy31
    That stuff really IS the shit.
  23. Just another variation on the stick and grease theme. I find a dowel pretty close in size, then wrap the end in duct tape to get the tight fit. Be sure to get all the air bubbles out of the grease and keep packing it in there. Finally, be sure to keep your face out of the line of fire unless you like the taste of grease :D
    I have never had these methods fail me.
  24. gdub
    gdub
    I used a 3/8 socket extension flipped around backwards. Fit the hole just right and the bushing popped right out.
  25. I like this idea! Oh yeah, BUY A NEW ONE! HOY(slang for i want to be cheap like Dan Collins)
  26. fab32
    fab32
    If you've got an old input shaft laying around just use that and a dead blow hammer to get the bushing out. I use wheel bearing grease, but any kind will work.
    Frank
  27. B Ramsey
    B Ramsey
    Perfect!
