Mine are missing, new ones are $150 or more based on the supplier, plus the shipping which we all have seen has gone through the roof. The half-assed pics of repros don't show them installed. You know where this going, right? I wanna make some and the task will be easier to sort out if I can see them in place. Thanks in advance, as always...
these? We had to make some for a 39 Woody, Bought some alum channel stuff at Home depot and a roll of 37 Ford door sill welting-worked out well and closed gap at bottom of doors. Looked like this on woody. carpet then went in channel and rubber flap sealed against door
Ok 'scrounge, that clears it up and similar to what I was thinking. I actually have some stock to play with. Who's got an OEM or repro set installed?
My 40 has em installed--they are the repops-the ones we made worked out well-made a set also for a 37 and 40 Woody as there are none available. We just rounded off the sq edge of the channel a bit to make em look a bit better. On one we used some rubber we found on ebay as well.
