Projects Peugeot 301 roadster pickup?
Discussion in 'Traditional Hot Rods' started by Mateusz, Jun 2, 2018.
  1. plym_46
    plym_46
    from central NY
    I have a Mk 1 sprite. It was lowered y simply restacking the springs. Car was modified fr hillclimb and autocross. The three or four leaves above the main spring were stacked under it, rebundled and remounted as stock. The drop was about 3 inches. Yes the suspension was a bit softer, but since the car had been stripped of trim, seats etc. It was about 75 pounds lighter and only seated one,the full set would have been over stiff. If you are removing sheet metal and won't be carrying a load. Might be worth trying. Its quick easy and reversible. If it doesn't work, another solution can be applied.
  2. plym_46
    plym_46
    from central NY
    Any updates??? Interested in your fix.
  3. Mateusz
    Mateusz
    Nothing special. I got no Time right Now. Remove a few leafes and its lower Now but not too much. Now i must to weld my frame together after widening.
  4. plym_46
    plym_46
    from central NY
  5. been awhile. any updates?
  6. Mateusz
    Mateusz
    Oh. I got no Time lately. Winter is comming So maybe now. I collect some parts right nów.
  7. JackdaRabbit
    JackdaRabbit
    from WNC
    I'm watching this one for sure. Never saw a`34 Peugeot before, straight up 1934 classic styling.
    If the frame is widened in the back the spring mounts are going to be inboard already so the axle connections don't need relocating.
    Mateusz likes this.
  8. Mateusz
    Mateusz
    mgtstumpy, Jet96 and leon bee like this.
  9. noboD
    noboD
    I like the look of your car, especially the hood.
  10. -Brent-
    -Brent-
    Those 1/4 elliptic spring mounts are pretty cool!
    PugetDude likes this.
