SOLD - SOLD - SOLD Pair of aftermarket spindles have bushings installed and are brand new and never mounted. Pair of aftermarket steering arms have a 1.75" drop and the tie rod mounting holes are tapered from both sides so the tie rod can be mounted above or below the steering arm using 11/16" Ford tie rod. The 2nd eye has been cut off the passenger side arm so these arms cannot be used with cross steering. Also included: 1 RH and 1 LH Ford Tie Rod End and 4 Allen bolts to mount steering arms to spindles. You will need a king pin kit to mount these spindles on an axle. They are $33 on e-bay. SHIPPING (AT COST) WILL BE PAID BY BUYER
