Hot Rods Paint Work.
Discussion in 'The Hokey Ass Message Board' started by GordonC, Mar 17, 2024.
  1. GordonC
    GordonC
    Guys I need a little info. I recently repainted the hood and front fenders on my A roadster i n single stage paint. The fenders came out pretty good but I had a problem with the gun when spraying the hood and it got some orange peel. I know, they almost always have some, but it was more than I'd like. So I wet sanded the whole hood staying away from the louvre area as much as possible, and then worked it with compound, and then finally buffed it out. It looks pretty good for the most part. In this pic you can see how it is. My question revolves around getting the louvre area to now more closely match the rest of the paint. I know it will probably be a lot of hand work (ok with that) so as not to damage the paint on the edges of them, but does anybody have any tips or ideas on how to approach getting the area between the rows up to the same level as the rest of the hood. I can't get in that area even with my small buffing machine so appreciate any help or info. 20240317_161304.jpg
  2. BJR
    BJR
    You need to do to the louvers what ever you did to the rest of the hood to get it to match. Lots of hand work.
    SS327 and GordonC like this.
  3. You can get mini pneumatic buffers fairly cheap. You will probably need to pick one of those up and then lots of hand sanding. Tape the edges so you don't cut through.
    GordonC likes this.
  4. GordonC
    GordonC
    I hadn't thought of a mini buffer but I'll check it out. I am ok with doing a bunch of hand work. Just wondered if anybody had some tips on what they have done that has worked out pretty good. Thanks guys.
  5. I would just sand it all down and paint it again....it would take less time and effort
  6. KenC
    KenC
    Let me know how the mini-buffer works out. I have one in the drawer that has never been used.
    GordonC likes this.
  7. Lloyd's paint & glass
    In my opinion this is the best option for a consistent look with the least effort. Usually when I try hard to lick my wounds, I wind up completely redoing it anyway.
    GordonC likes this.
  8. JohnLewis
    JohnLewis
    Miniature buffer with a cone buffing pad. Or they make buffing sponge pads that are coned for a drill. Typically you would use them for areas behind handles or mirrors, popular for in between rim spokes. One of those might work for you.
    Edit: You can get those in small sizes and different shapes as well. A hour glass shaped pad might work for you as well.
    GordonC likes this.
  9. HOTRODNORSKIE
    HOTRODNORSKIE
    Your going to have to cut the paint for sure, you can buy mini sanding block try starting with 1000 grit you might have to step down to 800 then step up to 1500 then go to 3000 Trizac finish with 5000 less buffing that way, Buff with a mini wool then finish with a mini foam pad protect those edges.
    GordonC and mikhett like this.
  10. GordonC
    GordonC
    I ordered a mini buffer tonight. I'll give it a whirl when it shows up and see how it works out. Worse case if need be is I sand it down and spray it again as noted above. Thanks.
  11. chopolds
    chopolds
    from howell, nj
    1. Kustom Painters
    And tape off the edges of the louvers, so you don't burn the paint off of them!
