Well here I am with a problem with the overdrive on my 49 Mercury. I want to by-pass the od relay and governer. I have replaced the solinoid and it test ok when connected to the battery, can I take a hot wire off the switch straight to the solinoid with a toggle switch in between. and not need a relay ? Will this work ? I have not tested the od governor but want to by pass and have a direct say when to up or down shift with the od. If some one has done this before please advise on the correct procedure. Thanks, Jack in Texas
If you do a search on overdrive info here you should find several good threads that cover your questions. Some include links to wiring diagrams for the type of system you are interested in.
Hey 49 Merc...Try posting in the general disscussion section & you'll get more answers...............
