This is a project, about 95% complete. Small rust in Cowl panel,other rust has been repaired or replaced. Door and windshield have been replaced. 59AB Flathead, Rebuilt before I purchased. Has early Navarro 3 x 2 manifold, 3 - 97s Carbs-rebuilt by Uncle Max of the Hamb. Rebuilt fuel pump, Edmunds alum heads. Ferrari fuel filter with a adjustable pressure regulator. C4 Trans w adaptor, Mustang floor shifter. Open drive differential adaptor. 1930 A Spring on top of rear axel. New Speedway front suspension, 4 wheel hydraulic brakes, stock A Frame, modified by moving front, cross member 2 inches forward, rear cross member Zed about 4 inches, F - 1 steering box-modified with adaptor- Radiator with thermal static control. License & Titled in Az. MUCH MORE Speedway Parts New #916 - 39516 Front Suspension #916 - 33006 FrontU Bolt Kit #916 - 3197 Brake Pedal Mount #910 - 11005 Air Filter x 3 #560 - 62713 Carb progressive linkage #910 - 13601 Headers #910 - 23101 Transmission Cooler Looking for a Early 60's Nova, Ford Fairlane, Falcon, long roof ok, must be a driver with min.rust, Patina ok.
