Projects ONE PIECE AT A TIME ('47 FORD COUPE)
Discussion in 'The Hokey Ass Message Board' started by topher5150, Mar 1, 2017.
  1. phat rat
    phat rat
    Just making sure you knew
  2. topher5150
    topher5150
    IMG_20180109_192353420.jpg IMG_20180109_202213130.jpg IMG_20180109_202222970.jpg
    Got bored tonight. I'm surprised the speed o is as clean as it is even has the quality signature on the back of the face, but I'm afraid the input on the speed o is pretty rusted up.
    1Nimrod likes this.
  3. topher5150
    topher5150
    I have a question, do I need to split the wishbone, and then order the spring? Looking a Posies site it seems like you have to split the bone then order the spring based off of the measurement, or am I way off?
  4. topher5150
    topher5150
    I found all the windshield trim, but it looks like one piece got smooshed and bent in the same spot. How would I go about making it look half way decent again?[​IMG][​IMG]
    Sent from my XT1710-02 using The H.A.M.B. mobile app
    1Nimrod likes this.
  5. slv63
    slv63
    No ideas, just following along
    1Nimrod likes this.
  6. Thor1
    Thor1
    Topher,
    Check out YouTube for videos on straightening, repairing, and polishing trim. If you search these topics on the HAMB you should find some information as well I believe. The damage shown in your photos above should be repairable. Good luck and please share your results if you take on this challenge.
    Thor
    1Nimrod likes this.
  7. Make a small anvil using steel ground to shape that fits inside (test fit to an undamaged area) and use that with plastic hammers on the outside. Often wondered if metal epoxy could be cast to fit and used as an anvil. Work slow, very slow and tap gently with hammers it is thin stuff. Avoid sanding/filing if you can unless you have super deep gouges. Polish as you would with any stainless once it is straight, machine or by hand.
  8. topher5150
    topher5150
    Thanks I will have to get that a try
  9. topher5150
    topher5150
    1Nimrod likes this.
  10. razoo lew
    razoo lew
    from Calgary
    Looks angled. But is that how the required caster comes about?
    Atwater Mike likes this.
  11. topher5150
    topher5150
    1Nimrod likes this.
  12. Wayne67vert
    Wayne67vert
    It's all in the camera angle. Take one from overhead.
    1Nimrod likes this.
  13. topher5150
    topher5150
    1Nimrod likes this.
  14. sawzall
    sawzall
    Nice steering box bracket ;-)
    1Nimrod likes this.
  15. topher5150
    topher5150
    Other then drilling a couple of holes, it fits quite nicely.
    Some one suggested that the cross member is angled for a little extra caster to improve the ride
    1Nimrod likes this.
  16. topher5150
    topher5150
    This was a very unproductive day today. I was hoping to mock up the front suspension, but I spent most of the day trying to get a bushing out of the spring. IMG_20180429_170722518_HDR.jpg
    1Nimrod likes this.
  17. topher5150
    topher5150
    1Nimrod likes this.
  18. topher5150
    topher5150
    Well that was a very unproductive day. Has planned on getting the spring on and getting the shock mounts in place. I spent all night wrestling this stupid spring in place. IMG_20180516_200104754.jpg
    1Nimrod and slv63 like this.
  19. topher5150
    topher5150
    I'm working on getting things roughed in but it seems like there's a lot of interference on the shock and the spring IMG_20180522_194107594.jpg
    1Nimrod likes this.
  20. topher5150
    topher5150
    Got a little work done today, but welding in this heat sucks buttermilk. IMG_20180617_164019279.jpeg IMG_20180617_170939888.jpeg IMG_20180617_172314133.jpeg IMG_20180617_175013427.jpeg
  21. Ralphies54
    Ralphies54
    You gotta turn up the heat a bit for those welds to hold.
    1Nimrod likes this.
  22. topher5150
    topher5150
    I will keep that in mind. I still have to the bottom and box the insides
    1Nimrod likes this.
  23. sliceddeuce
    sliceddeuce
    `Topher...……...A DVD of The Piano ??? I have lost all respect Grasshopper. looks like you are making progress...remember, I`m just up the road from you.
    1Nimrod likes this.
  24. topher5150
    topher5150
    Wait what... I'm so confused right now. Where abouts are you cuz I'm gonna need some help getting the rest of king pins out
    1Nimrod likes this.
  25. I have melted a clamp like that before as well. Get a bunch of cheap Chinese vice grip knock offs to start with, then look for good old c-clamps, used is great pick up one at a time till you have dozens, never too many clamps. What kind of welder are you using?
    1Nimrod likes this.
  26. topher5150
    topher5150
    It was too hot out and I didn't feel like looking for my c clamp
    1Nimrod likes this.
  27. topher5150
    topher5150
    Getting some ideas going. Now I need to do a cost analysis which includes cases of beer I'm going to have to give you guys to help me. Speak up if any of these dims look off IMG_20180704_215126595.jpeg
  28. sliceddeuce
    sliceddeuce
    uh...……….21 +21 +10 = …...54???....How about 52 ??
    1Nimrod likes this.
  29. topher5150
    topher5150
    be nice....I ran out of fingers and toes :p
  30. That's called "poor man car payments".
    1Nimrod, Kelly Burns and topher5150 like this.
