Projects OLDS Rocket with Six Pack Offy
Discussion in 'Traditional Hot Rods' started by Itchy-Pit, Mar 13, 2018.
  1. Itchy-Pit
    Itchy-Pit
    Okay boys. I was fortunate enough to bring this home. I'm planning on putting this in a 33 or 36 Ford. What advice have you HAMB gallery?
    AHotRod, ls1yj, Hombre and 6 others like this.
  2. Stogy
    Stogy
  3. Dago 88
    Dago 88
    I have one of those. :) Digital 042.jpg
    ls1yj, kadillackid, Jet96 and 3 others like this.
  4. footbrake
    footbrake
    It's really worth nothing , you should just send it to me, I'll trade you for a 265 ,lol
  5. Nice find. Any history on it? It has #8 heads? so it may be a 55.
  6. Paul
    Paul
    Editor
    Looks like a stock '55 with a log setup sitting on it.
    Very cool start, something worth building a car around
  7. Rickybop
    Rickybop
    I like flat heads and inline engines and all the rest, but I think my favorite era is the late 50s early 60s with big overhead valve V8s and 6 carbs. Jewelry, man. Cool, Itchy-Pit!
    Sent from my VS835 using The H.A.M.B. mobile app
  8. engine138
    engine138
    from Commack NY
    Sweet! nice find
  9. Uni-Syn is your friend!
  10. nochop
    nochop
    from norcal
  11. oldsjoe
    oldsjoe
    Good start! Gotta love those stacked Olds engines! Joe
  12. Hey that’s cool! Stuff it in there! I love ‘33 (‘34s) and ‘36s!
  13. J. A. Miller
    J. A. Miller
    from Central NY
    Nice find! What's the back story - craigslist?
  14. Itchy-Pit
    Itchy-Pit
    Thanks folks. I am super stoked. Clayton and I are going to make you all proud. Yes to the quiry. CL find and a BIG thank you to Austin for working with me. Got the crazy tranny, exhaust manifolds, starter and alternator too. 36 3 Window - (Avantar) or 33 Roadster. (Album). Either way - will be a runner. Once completed will revisit paint and pretty.
  15. bchctybob
    bchctybob
    ^^^what he said^^^ tell us more about the find and the cars. I spy a Hydro sitting on the floor also. Are the engine/trans hotrodded or stock with speed parts as part of the package?
  16. Itchy-Pit
    Itchy-Pit
    Craigslist find outside my turf in Fresno. Austin is a car guy/builder. Tag on motor says rebuild standard bore and crank numbers. Not sure build date as 3 3. March 73, 83, don't know. Looks fresh inside. Plugs looked good no oil or fuel fouling. Drivetrain was built for a 5o something Ford pickup dragster I was told. He had the slant tranny and other parts that came with the motor so we made a deal to keep it all together. I don't know if I will runt the auto but we'll see. One 97 has damage but all the linkage is there and we'll just see how it all comes together.
    Paul and Hollywood-East like this.
  17. christmas tree
    christmas tree
    need to check 1949 to 1955 internal balance 1956 and up external balance. The heads are 1954 and later.
  18. 392
    392
  19. Paul
    Paul
    Editor
    Not altogether true
  20. BJR
    BJR
    Is it legal to post engine porn like this Digital 042.jpg on this site?
    Dago 88 and hendelec like this.
  21. Don't mean to be a nit-picker, but just to set the record straight................
    "A six pack usually refers to the Chrysler (Mopar) carburetor setup which is three-two barrel carbs on an intake."
    Having run a few 6X2 setups in the old days, I never heard the term 6 pack outside of beer until Mopar used it as an advertising gimmick.
    AHotRod, kadillackid and Paul like this.
  22. christmas tree
    christmas tree
    Paul Its been a lot of years ago, however tell me about the gray areas,
  23. ROADSTER1927
    ROADSTER1927
    It is a twelve pack!
    AHotRod and Paul like this.
  24. jbob1944
    jbob1944
    from , Co
    Here is mine.303 Olds
    Gotha intake with 6-94s.
  25. Paul
    Paul
    Editor
    as for advice,
    post your progress here with plenty of pictures
    try to find some number 10 heads or mill yours fourty thousandths to get the compression up a little,
    Pay attention to push rod length and valve to piston clearance
    bore it over as much as you can safely
    get a fairly lumpy cam, solid lifters and McGurk 1.8 rockers
    put a stick transmission behind it, steel flywheel, Ford Long style clutch
    hot ignition, (true magneto with advance)
    build custom headers
    run all six carbs, center two set up as primaries, starting with standard jets and power valves 45 and 65
    run outer four as secondaries, start with bigger power valves, 61 maybe?
    when you hit the go pedal it will give it gobs of air, you will probably need more fuel charge at throttle
    read up on getting the 97s to act right as secondaries, if you can't get the throttle blades to seal tight try just cracking the idle screws.
    or just rebuild the engine to stock spec's and run the middle two carbs,
    should still be plenty of fun, less expense and easier to tune.
    AHotRod likes this.
  26. ROADSTER1927
    ROADSTER1927
    Did someone mention a 12 pack Olds------ Mine.:D P9300026.JPG
    AHotRod, dwollam and kadillackid like this.
  27. MotorCityDeuce
    MotorCityDeuce
    What kind of headers are you running on that?
  28. Choppedcoupe
    Choppedcoupe
    Get it running and leave it rough(?). Looks great the way it is!
  29. Itchy-Pit
    Itchy-Pit
    Choppedcoupe - I'ts hard not to dress it up. But i think I'm going to do my best diligence and see if I cant get it going with the least cosmetics / gaskets and see. Austin who sold me the motor said his mechanic looked it over and it had high compression. Took the valley pan off and it's super clean. There is a rebuild plate on it. He called the shop and the owner said they only use month and single date year. 3 3 could mean 73 83 93 March. I will certainly keep this thread updated as we go. But be patient. Lot's of projects and projects to peddle to fund this one.
    AHotRod likes this.
