i need to know what pressure plate and clutch to buy for a 51 303 that im settin up to run a lasalle... i assume the 51 and up olds one, but wanted to check..... also, throwout and other bearings needed... THANKS GUYS!
Olds fly wheels are drilled for Borg&Beck pressure plates, with 2 groups of 3 bolt holes, I used an International clutch disc from a PU, that has the same splines as La salle, Olds throwout work will work, if you are using Olds bell housing, I had to made a pilot bushing.
i would like more info on the bushing.. and the setup i need to run... annd pressure plate info too maybe?? this was already on an olds, so everything should be ok, i assume i wanna replace bearings and shit thjough
My pilot bushing ended up being one that was made for a ford transmission to Olds engine , not a La salle.trans.
also my new clutch disk was from Tennessee clutch. right here in Nashville. but I think he ordered it from some place in Indiana.
