Technical Nuetral saftey switch quesiton...
Discussion in 'The Hokey Ass Message Board' started by southerncad, Dec 24, 2018.
  1. southerncad
    southerncad
    OK, granted I should know, but will a bad neutral safety switch cause a "no start" problem, or a "no crank" problem? Thanx for any input.
  2. squirrel
    It sure can.....
  3. If the neutral safety switch won't complete the circuit in park or neutral, the engine won't crank. If it won't crank it won't start.
  4. The neutral safety switch is typically wired in series with the starter wire that goes to the solenoid. The NSS is closed when in park or neutral for auto trans, or when clutch pedal is depressed for manual. If the switch is acting up it could be open and not allowing the starter wire to have voltage at the solenoid.
  5. Bandit Billy
    Bandit Billy
    Easy enough to test. Wire around it.
  6. Wiggle the shifter while in park and key cranking. Shifter may be out of adjustment.
    Phil
    Chili Phil likes this.
  7. southerncad
    southerncad
    Thanx for the input, was trying to isolate the problem, 'cause sometimes it won't crank, and sometimes, it will crank, but won't start. Was wondering if the nuetral safety switch could be the problem. Guess I'll wire around it.
  8. Take my advice DON"T by-pass the NSSW.
    I inadvertently by-passed mine by jumping the start solenoid.
    3 fractures to my pelvis and a broken tailbone was the result.
    The Doctors told me the next day i was supposed to be dead.
    Treat the switch with a lot of respect.
    Chili Phil, zzford and olscrounger like this.
  9. squirrel
    The "cranks but won't start" is not a NSS problem.
    egads and Hnstray like this.
  10. BamaMav
    BamaMav
    from Berry, AL
    Cranks but won't start sometimes sounds like a key switch that is not making connection all the time. Dirty contacts and wear will affect them. They do wear out....
  11. Gman0046
    Gman0046
    Zuffen, great advice. Thanks for posting.
    Gary
    olscrounger likes this.
  12. Frank Carey
    Frank Carey
    A while ago we learned from Crazy Steve that some of us unwittingly put more current thru a key switch than it was designed to handle resulting in premature failure. I was guilty; mine failed. If you replace the key switch, consider using a relay to keep much of the electrical load off the key switch.
    Chili Phil and zzford like this.
  13. southerncad
    southerncad
    Thanx for the input re: key switch, will clean/replace it.
  14. donno
    donno
    What type relay and where?
