non solid axle "gasser stance" cars ... or trucks
Discussion in 'The Hokey Ass Message Board' started by Stumpuller, Nov 7, 2009.
  1. lorodz
    lorodz
  2. reichart90
    reichart90
    no straight axle here. aluminum horeshoe spacers under the springs and ball joint spacers. I had 62 chevy 409 station wagon with AC springs on the front but it pinned the bottoms of the upper a-arms onto the frame - super dangerous. Took them off right away (wasn't easy putting them in).
    I like the height right now. With 30" tall tires in the back... it sits level with the 27" tires on the front.
  3. reichart90
    reichart90
  4. 54fordgasser
    54fordgasser
    from Kansas
    that is perfect!
    Any more pics?
  5. lorodz
    lorodz
    any pictures of theses spacers ...
  6. chris55
    chris55
    I think this is what hes talking about.
  7. mart3406
    mart3406
    from Canada
    It wasn't a gasser, it was daily driver street car,
    but it definitely had a 60's Gasser/Mod Prod stance.
    Back about 1974 or '75, a buddy of mine had a
    plain-jane '66 Beaumont 2-dr sedan with a stock
    230 inline 6. The front springs were shot so he
    replaced them with a pair of he had lying around
    from a '67 396 Chevelle The big block front springs
    combined with the little inline 6 caused the front end
    to go sky high. To fix that, he leveled the car out
    by putting a pair of J78-15 tires on 15X8
    Corvette rally wheels on the back and a pair of
    D70-14 tires on matching 14X6 iChevy II
    rally wheels on the front. With the new springs
    combined with big & little rubber, the rocker
    panels were now more or less level, but about
    8 inches higher than stock.And in the front
    there was a good 12 inches of clearance from
    the top of the front tires to the lip on the wheel
    opening. The car was still a total dog with the
    stock 230 inch 6 banger, but it looked scary
    fast! anyway!!
    Mart3406
    the the rocker panels were now
  8. chris55
    chris55
    Got my springs today...woohoo! Hope to start on it after Christmas.
  9. reichart90
    reichart90
    yep, Chris55 is correct - those spacers are what I am using. I've used them for the past 3 years with no problems. I also use balljoint spacers that there is a picture posted of earlier in this thread... but they aren't necessary. I run stock springs... heavy duty ones were a no-go situation. The car has a nice ride height and it drives well too.
  10. So glad to see people that now what Gasser stands for. I have a set of C style ball joint extentions and a 57 Pontiac to put in my 56 for some extra attidude.
  11. lorodz
    lorodz
    where can i order these horseshoe spacers from ..
  12. I've seen them on ebay under gassers
  13. lorodz
    lorodz
    im checking rite now
  14. freebird101
    freebird101
  15. lorodz
    lorodz
    nothing on there
  16. evolvo
    evolvo
    from Seattle
    Here's the car I built back in '70 (?) Ball joint spacers, station wagon springs and a Olds rear end. I sold it to the guys on the door. Here it is at Capitol Raceway in MD pulling the left front.
  17. They show up at different times, seller will relist just keep checking.
  18. I see your from Seattle, have you taken that Volvo down to Bob,s in Burbank Ca. I've seen one thats looks like it with a Chevy V6.
  19. evolvo
    evolvo
    from Seattle
    No, I don't know Bob. I'm always looking to talk with other Volvo rodders though so if you find the guy get him to PM me, if he's a member that is.:rolleyes:
  20. Bob's is a restraunt that has a weekly cruz on fridays. The V6 swap must be the in thing for you guys, its nice how they fit. If i see the car again i'll let the person know. In keeping with the thread nice 55 from the days.
  21. Used a front clip with torsion bars out of a Chrysler new Yorker.....fully adjustable. :)
  22. IMBROKEN
    IMBROKEN
    from Roseau, MN
    Here is my "tribute" car. I used a '76-'77 Monte Carlo chassis under it, due to my chassis being completely junk. I liked it at first, but I really dislike seeing the frame. I am unsure if I should put it back on an original chassis with springs and spacers, or go straight axle. O well, it gets me around.
  23. Stumpuller
    Stumpuller
    I love it! my impala is begging for some air under the front!
    i like the spring over in the back. where its still nose up, but has like 3 or 4 inches of daylight over the rear tire and an uncut fender.
    like lifted all the way around.
    on a side note, i found a donor front axle for my O/T 69 C10 Ga**er. its out of a 91 2wd jeep cherokee. they just used an empty tube with no drive housing like the old dispacher jeeps. ball joints, disk brakes and its only 100 bucks! what do ya think?
  24. chris55
    chris55
  25. low budget
    low budget
    from Central Ky
    Ive got ball joint spacers and bigger coils.
    The ball joint spacers go in the top A frame to allow the bottom A frame and spindle to go down further and not let the top A frame bottom out on the top of the frame.
    I wanted 15s but ran across some 14s, They do help exagerate the distance between the wheel and the fender lip more.
    I need a 225 70 14 on the front instead of these lower profile tires on it now to raise it a little higher.
    oh, and yes that green 55 has the stepped spindles that uses 2 pair cut and welded together (I checked it out at Bowling green Goodguys)
    Also, I knew of a white 66 Impala for sale back in the late 80s that was sittin high front and back with ladder bars, new wide cragars and 50s in the back and skinnies in the front, It looked super clean and wicked.;)
  26. 5Wcoupe
    5Wcoupe
    from L.A., Ca.
  27. lorodz
    lorodz
    i was looking at a 57 gasser for sale on ebay..and saw these on the ball joint as spacers ...whats it made of..
  28. I am having a hard time finding them on Summits site. Any ideas/links?
  29. ok guys , from whats been posted here ive given up on the ball joint spacers
    and decided to go the heavier spring route but i can tfind new ones went to all the local parts houses and a truck spring shop
    any one know where to get them?
    i did buy a used set from a guy at thre ford super swap in columbus ohio this weekend he said they are fron a
    70 mercury cyclone with a 429 in it do you guys think it will give me the lift for my 57 sedan im hopeing for?
