Technical Non power GM master cylinder
Discussion in 'The Hokey Ass Message Board' started by MERCURYGUY, Dec 8, 2019.
  1. MERCURYGUY
    MERCURYGUY
    I had a non power GM dual master cylinder on my 32 Ford with front disc brakes without a power booster and the car stopped on a dime. I want to use the same setup on my 1951 Ford but I threw away the papers I had on the 32 when I sold it (dumb). Can some one let me know what the proper part number would be say an NAPA number or whatever to get the same unit. Thanks Mercuryguy
  2. squirrel
    We can guess....there were several GM cars available in the late 60s with manual disc brakes, including the Corvette.
    porknbeaner likes this.
  3. I was going to mention Corvette non power master. They could be had with 4 wheel discs and if I am not mistaken disc drum in the later models.
  4. squirrel
    pretty sure they were all 4 wheel drum through 1964, and four wheel disc 65 and later.
    power boost was an option, until some time in the 70s?
    Moriarity likes this.
  5. You are probably correct. I was thinking about the '70 that came in for a color change when Lynn was still alive. For some reason I am thinking that it was disc drum, but I crawled under a lot of old heaps back then. You are always more correct on things like this or at least I depend on you being more correct. ;)
    firstinsteele and slack like this.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
  7. In a good disc brake setup, is the master cylinder bore size related to the Piston size in the caliper? Or is bore size related to volume of fluid master can displace?
    In drum/drum setup, master bore same as wheel cylinder bore is a good starting point.
    At any rate, OP choosing the same master he had in a prior rod only makes sense if the rest of the brake system is very similar. This new rod is quite different weight Wise and also front - rear distribution is quite different.
    My bottom line, why not choose a master that is matched/compatible with other components of current build?
    Phil
    squirrel and Moriarity like this.
  8. Cree
    Cree
    from Montana
    Check out this I believe Early Vette 1” bore...
  9. My 51 Vicky with Nova front clip and 9" Ford rear has the Brake pedal still floor mounted runs the 67 Chevelle Master with No booster. Stops on a dime and gives ya change back. I don't know why I used the Chevelle insted of the Nova unit that would have seemed natural for the front unit.
  10. MERCURYGUY
    MERCURYGUY
    Many thaks guys for the info Mercuryguy
  11. jimmy six
    jimmy six
    Your 51 is heavier than your 32 so things cold be different. A smaller diameter MC will do a much better job with no power. Longer pedal movement but less foot pressure. My non power set up has 7/8” MC and 15/16 rear cylinders on 11” f-150 brakes. My car is 3500# and stops much better than all drums but not like power.
  12. 270dodge
    270dodge
    from Ohio
    EBay,4 PORT CORVETTE STYLE GM MASTER CYLINDER DISK/DRUM PROPORTIONING VALVE + LINES. 1 inch bore, manual disc- drum. About $100.
    That's what I just ordered.
