Planning to build a banger for my 30 Coupe. Need a low pressure fuel pump for Stromberg carbs. Currently have a K&N 1-4psi pump, but tired of listening to the click-click-click. Any ideas? Thanks ken
Check out the Edelbrock 17303. I needed a low pressure pump for Weber carbs and it happened to be on sale at the local Oreilly's. It is already mounted in a rubber case and is extremely quiet. It's a rotary pump, so no clicky sound.
I mounted my pump (near the tank) using relatively soft rubber about 3/8 inch thick at each mount flange.......reduced the noise to almost nothing.
Stay away from the red label Holley pump. Although mounted in rubber grommets, it still whines like a banshee.
Mount it with rubber isolator mounts used for mounting AC condensers Walbro pumps are pretty good and still made in the USA [not counterfeit ones]
I bought this pump from Amazon to replace the noisy one I had. Can't even hear this run: https://www.amazon.com/gp/product/B000C1LW0E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1.
