No spark
Discussion in 'The Hokey Ass Message Board' started by metal bender, May 14, 2010.
  1. metal bender
    metal bender
    from texas
    Got a 4 cly. distributor dose not fire number 3, fires 1 4 2 skips 3 not the wire, not the cap ???? help !!! :eek:
  2. Bigchuck
    Bigchuck
    from Austin, TX
    Are you saying that no spark comes out of the #3 wire, or that cylinder #3 is dead? If strong, blue spark jumps out of #3 wire, then plug, piston, valve train.
  3. Zerk
    Zerk
    How does the cam on the distributor look? Missing one lobe?
  4. metal bender
    metal bender
    from texas
    Dist. is new no spark on number 3 good wire and cap engine is fresh .
  5. 29nash
    29nash
    from colorado
    If you are getting spark through the cap on #3 post, then it's the wire......:D
  6. canman
    canman
    oscilloscope
  7. DrJ
    DrJ
    Compression test too.
    If it's a Volvo it's a flat cam lobe...
  8. metal bender
    metal bender
    from texas
    The egine is not the problem its the distributor dose not fire second hole ! cam in dist. good rotor good cap good wires good. what the hell is it ??
  9. 57FORD
    57FORD
    im assuming its a points type dist. if it is, get it to Cyl#3 is and see if the points are opening. if they are and the coil if firing then check resistance at the plug wire. (end to end) and see what the resistance is. then move the wire and see if it changes or reads Open lead (OL) on a DVOM. if the wire is fine and you swapped plugs from a known good cylinder then i would say you have a mechanical problem. dead cylinder, flattened cam lobe if the valves are not opening or a stuck open valve.
  10. 57FORD
    57FORD
    another thing did you swap any parts from a known good cyl to the bad one? like plugs and wires and see if it moved to another cyl?
    another idea is you might have a tooth or two missing from the dist gear or on the cam gear and its throwing things off. but i would think that would mess your timing up so bad that it wouldn't run.
  11. 57FORD
    57FORD
    plus alittle more info like what kinda 4 cyl. what car was it in or is it in?
    might help me help you figure this thing out:)
  12. metal bender
    metal bender
    from texas
    Hey 57 ford your close to the answer, I am going to see if the pionts open on numb. 3 thanks . A 4cly. 2.3 ford with injectors and all the good crap to run fast . :rolleyes:
  13. canman
    canman
    Injectors like EFI?
  14. metal bender
    metal bender
    from texas
    Got the bug out, pionts were not seated on the distributor plate properly . EFI no Hilbourns yes on gas :rolleyes: thanks yall
  15. 57FORD
    57FORD
    nice man glad you figured it out :)
