This has been claimed. Up for grabs is a matched ring and pinion gear set from a 1948 Ford Banjo rear end. The pinion has 9 teeth and the ring gear has 34 teeth, making this a 3.78 ratio set. Each gear has some pitting, as seen in the pictures. The ring gear is pretty bad in some spots, but the pinion is not so bad. The pinion has six splines on the input shaft. Free if you want it but shipping will be $16 in the continental US. Feel free to contact me with any questions you have.
