Technical Newbie
Discussion in 'The Hokey Ass Message Board' started by Rocky Rotten, Apr 2, 2025.
  1. Rocky Rotten
    Rocky Rotten
    Hey all! Excuse my ignorance I have never used or posted in a forum. My dilemma is this, I have a 50 ford shoebox that I want to put a 1989 5.7 engine in but I cannot seem to find an oil pan for that application. I have contacted a couple of companies but no luck. Any guidance or work around would be greatly appreciated
  2. DDDenny
    Think Chevy II
    51 mercules and chryslerfan55 like this.
  3. Rocky Rotten
    Rocky Rotten
    Where do I find a Chevy II oil pan for one piece rear main seal ?
  4. squirrel
  5. wheeltramp brian
    wheeltramp brian
    I used a Nova front sump oil PAN and the stock one piece PAN and made them into 1. I'll try and find a picture.
    Rocky Rotten likes this.
  6. wheeltramp brian
    wheeltramp brian
    20200820_160631.jpg Worked out great. I've got an extra new Nova front sump PAN If interested.
  7. I used a Chevy II pan, part of a V8 swap kit I found on eBay. The pan itself was a real POS. I had to straighten the rails and braze up some sketchy thin areas.
    If I had to do it again, I'd be looking at the notched one. Try to find dimensions if possible.
    lothiandon1940 likes this.
  8. Rocky Rotten
    Rocky Rotten
  9. Rocky Rotten
    Rocky Rotten
  10. squirrel
    been a long time since I looked under one of those cars, although lots of guys here have built them. I think the Moroso pan I linked to has a rear sump, with a big indent to clear the steering on the Chevy II. I don't know if there's something in the way back there on your car, perhaps you could post a few pictures of the engine bay to remind us?
  11. Rocky Rotten
    Rocky Rotten
    The steering linkage is back there, I believe that is why the chevyII front sump pan is used. The pan you listed looks like it will work. Gonna do some more research. I will post some pictures later today when I get home
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    Rocky Rotten and Toms Dogs like this.
  13. DDDenny
    If you go with the front sump oil pan you will need the matching Chevy II/Nova oil pump, pump pickup and distribitor/oil pump drive shaft.
    The pan rail will require (1) 1/4-20 tapped hole to mount the pickup stand-off.
    For reference see link below.
    Note:
    The longer stand is the regular Chevy II part, the short one is for the L79 style that mounts on one of the main bolt/studs.
    Read complete description
    Here:
    https://gmclassics.com/part/oil-pic...other-than-283-or-327-may-require-alteration/
  14. wheeltramp brian
    wheeltramp brian
    Also.
    One thing to remember is that when I put 1 on a 350 motor I had to clearance the oil pump for the crank. And then when I put one on a 383 stroker, I had to clearance it alot!
  15. I have my Chevy II pil pump install pictures on an external drive.
    But it is some work. I had to drill and tap a hole in the web of my block to secure the pick up tube. Tons of fun on a newly assembled long block.
    My kit came with a Melling oil pump. The longer stroke on the 350 will require some clearancing of the pump body.
    I locked the pump in my Bridgeport vise and used a large 90* countersink to remove the material. It took a couple of test fits to get it right.
