New Old guy ID help again
Discussion in 'The Hokey Ass Message Board' started by gcwred, Jan 24, 2009.
  1. gcwred
    gcwred
    Once again I need help IDing a piece. Can anybody tell me the year and model of this front. Thanks. GCWRED
  2. milkweed
    milkweed
    from SLC UT
    it looks like a 28 29 ford foor door sedan cowl
  3. gcwred
    gcwred
    Thanks for the info. GCWRED
  4. Not 28-29.............maybe 30-31..too wide for 28-29 not even sure if a Ford
  5. gcwred
    gcwred
    From New Old Guy,
    The cowl is 3'-10" wide, 2'-5 1/2" tall, 1'-3 1/2" long, if this helps. Here are two closer pictures of the firewall also.
  6. If you notice the belt line trim curving up and in front of lower windahield...Not a Ford
    (Look close at center photo)
  7. ChopTopJimmy
    ChopTopJimmy
    It's not a Model A cowl for sure.
  8. BenD
    BenD
    Alliance Member
  9. hotrawd
    hotrawd
    from lima,ohio
    I agree with BenD (check out the link). A friend of mine has a '29 Cabriolet with same cowl. You're lucky to have the matching hood. They're pretty hard to come by.
  10. gcwred
    gcwred
    From New Old Guy,
    You guys are pretty good considering you are just looking at a piece of a car and pictures. Going back to BenD's link it does look like a 28-29 Briggs or Murry. Thanks for your help. GCWRED
  11. It looks like the 29/30 chev. cowl i have in the shop
  12. pasadenahotrod
    pasadenahotrod
    from Texas
    As far as I know. ONLY the Model A Fords had cowl-mounted gas tanks SO that cowl is a 28-29 Fordor/Cabriolet cowl. It is missing the gas tank and the "spacer" section of the firewall but does have the distinctive Model A lower firewall profile.
  13. alchemy
    alchemy
    Anybody who says it isn't a 28-9 Ford fordor (or cabriolet) is dead wrong.
  14. loburban
    loburban
    It can't be 28-29 ford the lip back at the edge next to the door is not there it has to be 30-31 ford, Mr.Alchemy you are the one that is DEAD wrong. PLus whoever said not ford who else has a gravity gas tank in the cowl but FORD.
  15. alchemy
    alchemy
    Sorry Mr. Loburban, but you should study your Fords before you spout. How much money you wanna lay on this bet?
  16. alchemy
    alchemy
    Look at these.
  17. chaddilac
    chaddilac
    Man you guys need to study up on your fords... everyone's an expert all of a sudden and haven't even done the research!
    29 Ford fordor 60C blindback...
  18. Its a briggs are murry body. A murry I think ahd a round spot on the right lower cowl where a mercury head was.
  19. The37Kid
    The37Kid
    upload_2016-10-21_19-50-40.png Really old post but to educate the new to Ford people this is what a 1928-29 Ford Fordor/Cabriolet cowl looks like. That is a stock 28-29 gas tank under the one piece stamping. Bob
    timwhit likes this.
  20. jailbar joe
    jailbar joe
    interesting topic...I have the exact same cowl and was wondering what year....I thought 31' but now I know...
    only trouble with mine is it has had the window frame section chopped off and has no firewall...
    plan on making it into a roadster...got a fibreglass back section of a 28 a and will make the rest.
