Technical New 8" diff install
Discussion in 'The Hokey Ass Message Board' started by 3154tm, Apr 26, 2014.
  1. 3154tm
    3154tm
    hi all,the installation destructions that came with this gear specifically state, in bold letters and underlined, not to use silicone sealer on the gasket between the gear case and axle housing. it states i should install the gasket dry or with a thin layer of permatex. can anyone suggest reason for this? i've always used RTV before with out any problems.thanks
  2. 34dlxcoupe
    34dlxcoupe
    from Lincoln
    RTV is for bathtubs..It will break down if gear oil touches it.. Permatex would be the better choice.
  3. squirrel
    Dry if you don't mind it seeping, permatex if you want it to seal.
  4. Mike51Merc
    Mike51Merc
    The reason they bolded and underlined it is because they don't want you calling them when it starts leaking.
  5. 65COMET
    65COMET
    I use a THIN bead of "The Right Stuff",I believe it is made by Permatex. I also use Nylocks with washers on the studs,stops all leaks and they stay tight. ROY.
