Art & Inspiration Never seen this done before!!
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jan 17, 2020.
    catdad49 likes this.
  2. bigdog
    bigdog
    Seen it done before, pretty much just doing something to be different. Definitely no performance advantage.
  3. Nitro crew chief
    Nitro crew chief
    from Illinois
    I've seen it done before, but I don't know much about it, I'm sure someone much more knowledgeable then me will chime in. I'd like to hear it run and see how it sounds.
  4. Slopok
    Slopok
    That's nothn', ever see the flathead V8 with only one head run???
  5. big duece
    big duece
    from kansas
    How much shit from the front tires get sucked in the carbs??
  6. AngleDrive
    AngleDrive
    from Florida
    Camshaft is ground so exhaust valves become intake valves and intake valves become exhaust valves.
  7. Yeah the camshaft was the first thing i thought about, a guy here at work just showed it to me, I'd never seen it done. And yeah i know there's no advantage other than looks, but it looks cool :cool:
  8. Photo is about 10 yrs old at least, just a novelty act
  9. hotrodjack33
    hotrodjack33
    I've seen both a flathead V8 and a Model B 4cly that fired on half their cylinders while the other half of the cylinders were used as a compressor. Farmer ingenuity.
  10. So it's just for looks?
  11. fourspd2quad
    fourspd2quad
    Yup just like Swade's avatar unfortunately. :(
  12. Smaller exhaust valves become the intake.Bigger intake become the exhaust.
  13. What a waste of time... cars are for driving, pictures are for looking at :D
    hotrodjack33 likes this.
  14. Atwater Mike
    Atwater Mike
    Just look at the valves, ports, and all things 'breathing'. Efficient? Not in THAT direction...
    Remember everything you read since the 4 banger era? Port and relieve, (flatheads) Polish intake ports on the OHVs!
    Now, just imagine being the fresh atomized charge rushing through the restricted port size of the exhaust path.
    Bet it ran better NATURALLY aspirated...
    Lloyd's paint & glass likes this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
    I have seen that car run, sounds anemic......there is no advantage to that, just like irishsteve said, big exh valves and tiny intake valves. dumb idea
  16. 56sedandelivery
    56sedandelivery
    Seen it done with motorcycle carburetors before; those are probably the same. The front mounted/relocated distributor would make the SBC advantageous is some chassis where the SBF has been more often used. Some sort of remote water pump has to be used, and there is a stub drive so the camshaft still drives the oil pump. As far as swapping valves goes, they could use inserts and regrind the seats to use larger intakes and smaller exhaust. It's all just not worth it! So, it had a good beat, and I liked the lyrics, but it was kinda hard to dance to, so I gave it a three. I am Butch/56sedandelivery.
  17. Do you think they was drunk and said "imagine this shit, I'm gonna put my carbs where my headers are supposed to be!" Lmao
    hotrodjack33 and Budget36 like this.
  18. Oh no......your giving HRP a run.......
    scotty t, kidcampbell71 and swade41 like this.
  19. Oh did he get drunk and do it? :D
  20. doyoulikesleds
    doyoulikesleds
    p135215_largeBuick_Nailhead_Powered_DragsterPassenger_Side-1.jpg might be where they got the idea
  21. hotrodjack33 likes this.
  22. 302GMC
    302GMC
    from Idaho
    The idea has been tried for at least 80 years. It hasn't worked yet.
  23. blowby
    blowby
    from Nicasio Ca
    I see at least two benefits. Remove spark plugs on a hot engine without burning fingers and automatic windshield de-icing.
  24. doyoulikesleds
    doyoulikesleds
    I have read that it helped on the nailhead with a blower.
  25. Think the parts house has the correct "exhaust manifold" gaskets lmao! I thought it was pretty cool when he showed it to me. Just thought I'd throw it on here and see if it was for real or just for looks o_O
  26. Just like Lone Watie said.... All I have is a piece of hard rock candy. But it’s not for eatin’. It’s just for lookin’ through
    williebill, 32Dan, 62rebel and 3 others like this.
  27. nochop
    nochop
    from norcal
  28. hotrodjack33
    hotrodjack33
    C'mon Lloyd, you're not fooling anybody here. We all know this is exactly what you're planning for the Sedan Delivery...carbs in the fender wells and exhaust sticking out of the hood like Hilborn injectors:D:eek::D
  29. fordor41
    fordor41
    "farmer ingenuity". we used to rent gas compressors that had SBF engines, 4 cylinders ran, 4 cylinders were compressor
    Boneyard51 and hotrodjack33 like this.
  30. mopacltd
    mopacltd
    After talking to Tom Hoover( the Godfather of the Hemi ) He stated the the longer the stacks, the more horsepower it made. The only restriction was astetics(sp).
