Need wiring info for 1950 Merc
Discussion in 'The Hokey Ass Message Board' started by 59elky, Jun 1, 2007.
  1. 59elky
    59elky
    I am rewiring my 50 Merc. and need to know how the wiring hook up at the original steering column. I need to know what color wires go where. I have 2 white, 2 blue, 1 red, 1 black and 1 yellow wires.
    There should be a feed from brake switch.
    Feed from flasher
    Horn to relay.
    Front right turn
    Front left turn
    Rear right turn-brake
    Rear left turn-brake
    Please help guys I want to get this finished this weekend.
  2. blown49
    blown49
    Straight out of the manual but the colors don't match what you have. If this post is not clear e-mail me @ ecsllc@bright.net and I'll send to you. The pic is only 3" x 4" in the manual.
  3. 59elky
    59elky
    Thanks Blown49, but can you make it any larger so I can read it.
    Thanks
  4. SlowandLow63
    SlowandLow63
    from Central NJ
    I don't know if Ford is dif from Merc but horn relay wire comes out of the bottom of the column on my 51. That might help eliminate some things.
    Ask Unionvillehaunt, he could probably recite it for you off the top of his head.
  5. slddnmatt
    slddnmatt
    i went and checked my 51 , but my colors differ from yours.
