My computer crashed and lost all my files. Along those I had a diagram on how to wire my 250 motor..now I can't find it, try "search" and all...Can some oen post one for me. I have a two post starter "R" and "S" only, a one wire alternator...I will appreciate any the help.
For the electrical gurus out there...If I just want to start my engine (not fully wire just to make sure it is running) I can run a wire from the positie side of the batery to the "R" side of the starter and the poitive side of the coil. Run the negative side of the coil to the distributor and the negative side of the battrey to the engine block....and simply jump with a screwdriver the "R" side of the starter to the "S" side...right?
Just run a wire from the + side of bat to + side of coil. Jump from battery terminal on starter to S terminal to crank.
I am having a bad run...I can't get my engine going...it spins and spins but won't turn over. Check timing, spark and gas...all there.... Now looking for someone to make it run for me
