I have been using photoshop all day and am having problems getting any results...could someone that is experianced enough with it either alter the attached pic or tell me what/where to begin on getting the desired results? I am trying to use a Gloss black paint job, with a white roof as well as the area between the front trim. I have tried to touch up the rims/chrome. The last thing that I tried to do was lower it almost to the ground, all of this I failed miserably at, any help would be appreciated
TP I would help but I am slammed at work! You need to make tight selections for each area you plan to colorize. Make separate layers for each selection/color. As far as lowering your sled. You need to make a duplicate layer of your image and mask out the part you dont need, then slide it down to the ground. You can IM me if you want. But I need to wait till tonight at the earliest to offer any more help. Slim
Photoshop is a difficult and complicated piece of software. You can't expect simple results. There are thousands of Photoshop tutorials for all the different versions all over the internet, you just have to look.
