Can one of you look this up or do you know off the top of your head ?? What Buick Dynaflow automatics are a direct interchange in a '60 with a 401 nailhead ? Thanks, Steve weim55 Colorado
Hollander number for '60 Dynaflow is 526, one year only. Interchange Hollander number 525, '59 year, check converter and rear bearing retainer, switch rear yokes to use with '60 Interchange Hollander number 568, '57-'58 year, interchange less U-joint. I know the '59 I used to own had a closed driveline. Does your '60 have a closed driveline?
