Ok.. I need some help... I have a 1951 331 Hemi with the extended block. I have removed the bolts from the transmission, bell housing and lower block. I can't tell how to remove the transmission. Anyone done this before??? I am trying to remove the bell housing and transmission so I can get it down to the block for the machine shop.. Any help is greatly appreciated...
Depending on what you have for a transmission, I would say you probably need to remove the torque converter to flywheel bolts if this is the semi-auto trans with safety clutch.
It is the semi-auto with safety clutch... How do you get to the bolts to remove on the torque converter to the flywheel..
try this link: http://www.imperialclub.com/Repair/Lit/Master/057/index.htm IIRC: u first remove the transmission from the bell housing. There might be a bolt you need to get from inside the bell housing and that might be accessible from the bottom, after removing the torque converter inspection cover. Check out the link and see if that helps. I will look it up in my MM tonight.
That is what I was afraid of.... I started with my 5/8 wrench and couldn't get the leverage I need to break those loose. Was afraid I was going to mess up the nuts by rounding off the edges...
Either buy a very long combination wrench, or intertwine two combination wrenches together to get the leverage you need. Also once you have the wrench(s) on there real good, use a hammer and hit the farthest end of the wrench(s) a few time to loosen up. A little pentrating oil on the nuts might help too. BTW: Did you get the transmission off the bell housing? Like I said, I think the trans will come out by itself if it is anything like my 54 Powerflite is. There is a sleeve which connects the transmission shaft to torque converter.
I have a couple of books to look at tonight, so I will try and get back with u after going through the procedures.
1957 Motors Manual. If you have a good library with good reference book section, u can just copy what you need. Otherwise check out some of the classic car bookstores or HEBAY! http://cgi.ebay.com/ebaymotors/Vint...40301563828QQptZMotorsQ5fManualsQ5fLiterature
Ok..Thanks for all the help...Got the transmission and bell housing off.. Man..is this engine heavy. Had to rig up front support to put it on an engine stand. Trying to get the front timing cover off now... I am use to small block ford stuff and this guy is heavy and stubborn..
And it's real fun when you had moisture in a couple cylinders, and you cant turn the crankshaft!! Took me a couple days on mine!
