Hot Rods Need coupe answer
Discussion in 'The Hokey Ass Message Board' started by larry k, Nov 26, 2018.
  1. larry k
    larry k
    Can I install a new fuel tank in 1940 ford coupe with body on the frame ???
  2. alchemy
    alchemy
    Yes but it ain't easy.
    lothiandon1940 likes this.
  3. This cannot be said enough....
  4. olscrounger
    olscrounger
    Yep==done quite a few--a bit tough but can be done.
  5. larry k
    larry k
    Thanks all for your help??? . I was afraid of what your answers would be , just hoping I was wrong!!! Getting ready , to start cussing it in .
  6. Car
    Car
    from the desert
    Little difficult but it can be done indeed
  7. Gray Ford
    Gray Ford
    from Illinois
    Prepare to learn "New Words"......:)
  8. MIKE STEWART
    MIKE STEWART
    I changed out a original 1940 Ford Coupe tank - set years with crudded up old gas and flakes. Got the original tank out OK - but tight. Bought new repo - Drake stock metal tank - had to take a 6 inch 50 grit grinder to the sides and trim slightly - then took a thin body shop bumping spoon to slide it past the frame rail. Repo fit little tighter than the original.
    olscrounger, 3340 and lothiandon1940 like this.
  9. yep, tire spoons will help pry it out and in.
  10. There have been some threads about this in the past with some tips. Do a quick search. I'm too lazy.
    scrap metal 48 and Hnstray like this.
  11. 3340
    3340
    Yes, really not a terrible job
    scrap metal 48 likes this.
  12. scrap metal 48
    scrap metal 48
    Fairly easy on my 38 sedan(avatar)...
  13. olscrounger
    olscrounger
    What he said--orig will come out easier than new one will go in-follow his advise-repo tanks need a little adjustment as he mentioned-both Drake and Tanks
    MIKE STEWART and lothiandon1940 like this.
