I have what is believed to be a 1940 chevy hood. A potential purchaser of the hood has a 1941 chevrolet in another city. We're simply trying to find out if the two hoods were the same or similar enough to fit and be used. We realize that the trim on the 40 hood will be different from the 41. Comments will be appreciated.
different part numbers...but yeah, that's a good question. Is the only difference in the holes in the sides? or is there something else different? The 1940 chevy was all by itself, for the most part.
Hi Jim, The '41 hood sides are part of the hood while they are separate on the '40. A guy might be able to turn a '41 hood by trimming, etc into a '40, but probably not the other way around. Charlie
The 41 is quite a bit wider at the cowl than a 40. They look similar but i really don't think they interchangable without major metal work.
The '41 hood 'sides' are not part of the hood, they are part of the fender. On'40 models they are a separate panel as you say. The hoods themselves are very similar, as shown in the pics, but as also stated, the cowl is several inches wider on '41. Ray
The '41 cowl, front end sheet metal and doors are a one year deal too. From the cowl back.....roof, quarters deck, rear fenders....'41 thru '48. Ray
^^^^^^. Yes, it has been proposed before and I have seen a photo some years ago of what I seem to recall was a GM prototype of a '41 Chevy Aerosedan. Maybe it was a "one off" by a hobbyist.......I just can't say for sure. In any case, it would be relatively easy to mate a '41 cowl to a later Aerosedan rear body section but the doors are more problematic. '42 and later door leading edge, outer skin, and possibly the hinge placement, is different from '41. I "think" the 2 door Sedan and Coupe doors are the same length as the Aerosedan, but the upper door frame is completely different among the three. I believe that could be resolved by using '41 doors with the '41 cowl and reworking the doors by grafting on Aerosedan upper door frames and using the Aerosedan's window regulators and glass. Ray
