Hot Rods Need brake light help please
Discussion in 'The Hokey Ass Message Board' started by 396/425, Jan 7, 2019.
  1. 396/425
    396/425
    im redoing a 1960 Ford Starliner. My left brake light comes on bright when I turn the headlights on. But doesn’t work at all when I turn headlights off and hit the brake pedal. The right side works fine. Any help is appreciated. I hate electrical gremlins because I’m no electrician.
  2. Those are two totally separate circuits, so you have a wire crossed somewhere. That wire to the light should go to the turn signal switch, it's not doing so now. You'll have to trace that back and find out where it's wrong.
  3. Boneyard51
    Boneyard51
    You’ve got wiring problems. Problaly your tail light and brake light wires are crossed or touching each other.
    Bones
  4. First check that the bulb is in the right way (short & long locating pins in the right slots). Next, check your ground connection to the light fitting. It's usually a bad earth/ground which gives weird faults like this.
    squirrel and Bandit Billy like this.
  5. junkyardjeff
    junkyardjeff
    I had the contacts on the bulbs melt and touch so check the bulb first.
  6. theboss20
    theboss20
    Wrong bulb, bulb in backwards, bad ground (most common problem)
    Sent from my iPad using Tapatalk
    egads and Bandit Billy like this.
  7. 396/425
    396/425
    Well I found it. Fixed it. The reason is so stupid , I’m not sharing it, because my stupidity will probably get me kicked off here. Thanks for the input , boys. Appreciate you all.
    catdad49 likes this.
  8. theboss20
    theboss20
    We all have been there, done that...that is why we know what to suggest...in fairness to this forum we need to know what you found.
  9. 396/425
    396/425
    I had the two wires in the wrong holes. AND THEY WERE MARKED. I’m making an eye doctor appointment tomorrow.
  10. theboss20
    theboss20
    Happens...believe me
  11. junkyardjeff
    junkyardjeff
    I do stuff like that all the time.
    theboss20 likes this.
  12. GeezersP15
    GeezersP15
    from N.E. PA
    If that was your worst mistake, you're doing a lot better than most of us!:D:D:D
  13. Buddy Palumbo
    Buddy Palumbo
  14. Least you didn't have the right side wires in the left side holes!
    bobss396 likes this.
  15. 41rodderz
    41rodderz
    from Oregon
    It's all good. Everyone has been down the wrong path before. :D You learned .
  16. I had a crossed wire on the rear of my '59 Ford, an easy fix but again, everything was marked and labeled. A bad bulb will have you talking to yourself too. It may look good but... I always try to have a couple of good old 1157 bulbs around that I KNOW are good to help diagnose what you describe.
  17. X-cpe
    X-cpe
    I'm glad you posted the reason and cure. We all need occasional gentle reminders not to skip over the things "we know are right" when diagnosing our own problems. Sometimes it is hard to back off and treat our own problem like it was one brought to us by someone else.
  18. jimmy six
    jimmy six
    I mentioned this before here. Go to Classiccarwiring.com and order a 11-1/2"x 17" laminated wiring diagram for your car. It shows everthing including the wire colors...
  19. You passed the official H.A.M.B. initiation test and are welcomed into our brotherhood with open arms. If you haven't done it wrong - twice - and were insistent at first that you checked the easy stuff at the beginning, then you haven't really had the gearhead experience.
