Hi everyone. I can't remember what its called. Its an early ford design I think, so maybe 30s-40s? It has two links that connect to the axle and it has a single pivot point in the middle thats like a 'ball joint'. Its similar to a 2 link I guess but it both bars share the same pivot point. What is it called? I'm trying to find pictures. I thought it was banjo rear end, but I realized that was something else. Thanks all.
I think he means the British design split axle that Sydney Allard used . An I beam Ford axle cut in two and then joined up again on a centre pivot point.
The banjo is the differential, calld such as when the axle tubes are taken off the center section is the shape od said instrument (of mass annoyance!) If its the same as the onein the pic below Striper is spot on. Doc.
